Towing a trailer
/ Towing a trailer #41
If a fan "pushes" air from the engine compartment outward through the radiator, it would be drawing warm air from around the engine instead of cool fresh air from outside; disadvantage. On the other hand, it would plow dust and grass away from the grill and outside of the radiator instead of of sucking it into it; advantage. Now which is best? I have no idea. But I do know that the only time my temperature gauge gets to the halfway mark or above, I need to stop and clean the debris off the front end.
/ Towing a trailer #42
9N Fords blew, 8Ns sucked. People are still argueing which is best 60 years later. I guess if you wanted to you could have a puller for the winter and a pusher for the summer. Ditch the crank driven fan and install an electric fan with a reversing switch. When the radiator plugs, reverse the fan. When you're cold, pull the air. Get a little hot, reverse it. I might try it someday.
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2020 ASV RT65 (A60462)
John Deere 12in Channel Tooth Bucket Excavator Attachment (A60352)
John Deere 12in...
296385 (A57192)
296385 (A57192)
(INOP) 1996 FORD F150 SINGLE CAB TRUCK (A59823)
(INOP) 1996 FORD...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
