3-Point Hitch Towing a RV with a John Deere 2320
   / Towing a RV with a John Deere 2320 #11
Easy job for a tractor and I'd have no concerns on flat ground. I ferry around my flatbed trailer loaded with gravel all the time and it weighs more than that. Go slow.
   / Towing a RV with a John Deere 2320 #12
My little MF 1010 was a "yard mule" at an RV dealer apparently it did a great job of shuffling trailers around on flat yard and in and out of shop! Sorry no pictures!
   / Towing a RV with a John Deere 2320 #13
I have moved my 3000 lb boat on a double axel trailer around with my Honda rancher 420 ATV- pulls it just fine
Can you send me a link or info on wiring an off-on trailer brake switch I could use with my tractor? Thanks
   / Towing a RV with a John Deere 2320 #15
Etrailer has good trailer wiring diagrams & documentation. Probably best getting a cheap brake controller & using the manual engagement lever/switch on it.
   / Towing a RV with a John Deere 2320 #17
I would buy a socket that matches the trailer plug, then wire it like this.
Bruce
   / Towing a RV with a John Deere 2320 #18
You could wire a dead man switch so the trailer brakes are applied if it breaks away from the tractor towing it. The batteries on board the trailer could be the power source for this emergency breakaway option.
   / Towing a RV with a John Deere 2320 #19
There should already be a breakaway cable at the hitch. Just fasten it to the tractor.
Bruce
   / Towing a RV with a John Deere 2320 #20
I pull my 6000 pound 27’ camper all the time with my John Deere 2520. No problem. I love the ability to just pick it up with the 3pt and not have to use the jack.
My yard is also flat.
As mentioned there is no down pressure on the 3pt and you can do damage if the trailer tongue lifts up on the 3pt arms. I have a small trailer with a 500 gallon water tank that likes to do this when in reverse. Easiest way to prevent this from doing damage is to have a chain down from the 3pt trailer mover to the draw bar of the tractor that will limit the height from going to the top extreme,
If you wanted brakes for emergency rig a rope to the camper breakaway cable and give it a pull out if needed. I find that I am moving so slow around the yard that I don’t even use the tractor brakes.
One thing I have found is it is extremely difficult to back up as i don’t have mirrors on the tractor that reach passed the trailer and you are sitting centered on the trailer.
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2011 Isuzu NPR 14FT Box Truck (A56858)
2011 Isuzu NPR...
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A58018)
2005 PETERBILT 379...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
