Towing 14K trailer
/ Towing 14K trailer #41
Bumper pull... is this discussion really about hooking your trailer up to a ball mounted on the rear bumper??
Or is this about towing with a weight distributing hitch that is mounted to the truck frame?
My 3/4ton Chevy is rated to tow a trailer up to 14,700lbs. And the total Gross Combined Weight Rating (GCWR) is 22,000lbs. I have a Class IV or V hitch.
When I brought my JD 110 and attachments up from Washington state last year the trailer and load weighed 13,760lbs. The trailer title lists the trailer weight at 3,500lbs.
Now.... the heaviest ball and hitch I could find was only rated for 10,000lbs!!! So, technically I could have been cited and fined for towing without adequate equipment. As, the trailer and load exceeded the capacity of the ball hitch; by almost 2 tons.
(Anybody ever seen a ball and hitch that fits a standard sized receiver rated for more than 10K??? Let me know; cause I'd buy one if I could find one! :D)
And yes, I don't believe you need a CDL in Alaska if you're working with less than 26K GCWR. :cool:
AKfish
/ Towing 14K trailer #42
AKfish
When we are talking bumper pull we are talking off the rear of the truck. As you and many know, the bumpers are usually rated at a max of 5,000#.
Your truck has a max tow limit of 14,700# but that is off the 5th wheel or GN. GM 2500 series trucks are limited to about 12,000# off the Reese style receiver hitch.
As for the ball mounts I have seen them rated upto 15,000#. You have to hunt them out. You will not get them at your local WalMart. You must order them through a good RV dealer or mail/internet hitch company. The problem you have is a common one. I sold a boat to a guy and he showed up at my shop to pull home his new 14,000# boat with a bar and ball that were rated at 6,000#. I had to sell him one of mine and order a new one.
The hitch problem has been solved for 3/4 and 1 ton trucks. Ford was first with a 2.5" unit and the aftermarket followed. GM now puts 2.5" hitches on all the 3/4 tons and up. Not sure about Dodge but I do not think they have upgraded yet. These hitches are about 50% stronger than the factory 2" units.
Chris
/ Towing 14K trailer #43
I bought a new deckover bp last year & needed a new ball mount & ball. Went to my local steel supplier who also stocks trailer hardware & picked up a 2" 20,000 forged ball mount & 30,000 ball with 2" riser. These parts fit the height I was after but the trailer is only 14K.
I took the trailer with a 6' level, tape measure, then mixed and matched parts in his parking lot until I got the ball height right.
Find a retailer who is serious about trailer towing. The hardware is out there.
Sold the old trailer and it's pintle/ball combo with 15 ton rating.
/ Towing 14K trailer #44
(Anybody ever seen a ball and hitch that fits a standard sized receiver rated for more than 10K??? Let me know; cause I'd buy one if I could find one! )
I have a 14K/2K ball mount and crazy as this sounds they are mostly found in aluminum. It must have to due with no welding done to the billet design. Mine is a Diversi-tech unit easy found online even maybe Epay. And it is 2" because I couldn't find (go figure) the rise I wanted in 2.5". Make sure you order the right hole for your ball in whatever you get.
/ Towing 14K trailer #45
That is not correct
Here is the link for you
DK45S/10k Trailer - Page 3 - TractorByNet.com
Duffster,
If you read my post and the rules you will see that in NY State anyone with a regular drivers license (Class D) can now tow a trailer of more than 10K providing the GCVWR of the truck and trailer is less than 26,000 lb. That also means than anyone with a class B can do the same as long as the GCVWR of the truck and trailer is less than 26,000 lb.
A class B CDL license also allows for operation of a single vehicle of more than 26,000 lb.
If the class B operator decides to tow a trailer he is limited the same as a class D operator of not more than 26,000 GCVWR for truck and trailer. Such as a 12,000 lb truck towing a 14,000 lb trailer would be legal with a class D or B.
If the truck alone weighs more than 26K a class B CDL is required. If the class B operator is driving a truck the weighs over 26K and wants to tow a trailer he or she is then limited to 10K.
I don't know how much simpler I can make it and for NY this is correct.
According to Builders and Tinmans PA posts you need a class A for a truck to tow a trailer over 10K which isn't the case in NY anymore.
/ Towing 14K trailer #46
Duffster,
A class B CDL license allows for operation of a single vehicle of more than 26,000 lb.
I suggest you reread Builder's & Tinman's posts again
See the DK45S/10K trailer post for NY and PA license requirements for trailers over 10K. If the GCVWR is under 26,000 lb. NY doesn't require a CDL, PA does.
This is the part that is incorrect;)
/ Towing 14K trailer #47
Duffster, What part of this are you saying is incorrect. Are you saying PA now allows trailers over 10K without a CDL or the NY part not requiring a CDL?
/ Towing 14K trailer #48
Neither NY or Pa require a CDL for a trailer over 10k if the combo is under 26k
Please post the part where it says PA requires a CDL for a 10k+ trailer if the combo is under 26k
/ Towing 14K trailer #49
Default Re: DK45S/10k Trailer
http://www.dmv.state.pa.us/pdotforms...rms/mv-70S.pdf
What Class of Driver's License Do You Need?
In Pennsylvania, driverç—´ licenses are issued specifically for the class and type of vehicle you operate. Therefore, the class of driverç—´ license you should have depends specifically upon the type of vehicle you operate. Generally speaking, the majority of applicants for a Pennsylvania driverç—´ license will be operators of regular passenger vehicles, pick-up trucks or vans.
Classes of Driver's Licenses
Non-commercial Driver's Licenses
CLASS A (minimum age 18): Required to operate any combination of vehicles with a gross weight rating of 26,001 pounds or more, where the vehicle(s) being towed is/are in excess of 10,000 pounds. Example: Recreational Vehicle, when the towing vehicle is rated at 11,000 pounds and the vehicle towed is rated at 15,500 pounds (total combination weight of 26,500 pounds).
CLASS B (minimum age 18): Required to operate any single vehicle rated in excess of 26,000 pounds. Example: Motor homes rated at 26,001 pounds or more.
CLASS C (minimum age 16): A Class C driverç—´ license will be issued to persons 16 years of age or older, who have demonstrated their qualifications to operate any vehicles, except those requiring a Class M qualification, and who do not meet the definitions of Class A or Class B. Any firefighter or member of a rescue or emergency squad who is the holder of a Class C driverç—´ license and who has a certificate of authorization from a fire chief or head of the rescue or emergency squad will be authorized to operate any fire or emergency vehicle registered to that fire department, rescue or emergency squad or municipality. The holder of a Class C driverç—´ license is also authorized to drive a motorized pedalcycle (a motor-driven cycle) or a three-wheeled motorcycle equipped with an enclosed cab, but not a motorcycle.
CLASS M (minimum age 16): A Class M driverç—´ license will be issued to those persons 16 years of age or older who have demonstrated their ability to operate a motorcycle or motor-driven cycle. If a person is qualified to operate only a motorcycle or motor-driven cycle, he/she will be issued a Class M driverç—´ license. If your motorcycle is less than 50 CCs, an ? restriction will appear on your driverç—´ license. This restriction prohibits you from operating a motorcycle 50 CCs or larger.
Commercial Driver's Licenses - Classes A, B or C
CLASS A (minimum age 18): A Class A license is issued to those persons 18 years of age or older who have demonstrated their qualifications to operate any combination of vehicles with a gross combination weight rating of 26,001 pounds or more, provided the gross vehicle weight rating of the vehicle or vehicles being towed is in excess of 10,000 pounds. The holder of a Class A license is qualified to operate vehicles for which a Class B or Class C license is issued. Where required, appropriate endorsements must be obtained.
CLASS B (minimum age 18): A Class B license is issued to those persons 18 years of age or older who have demonstrated their qualifications to operate any single vehicle with a gross vehicle weight rating of 26,001 pounds or more or any such vehicle towing a vehicle having a gross vehicle weight rating of not more than 10,000 pounds. The holder of a Class B license is qualified to operate vehicles for which a Class C license is issued. Where required, appropriate endorsements must be obtained.
CLASS C (minimum age 18): A Class C license is issued to those persons 18 years of age or older who have demonstrated their qualifications to operate any single vehicle with a gross vehicle weight rating of not more than 26,000 pounds or any combination of vehicles, except combination vehicles involving motorcycles, that does not meet the definition of a Class A or Class B vehicle. Where required, appropriate endorsements must be obtained.
NOTE: You must be 21 years of age or older to operate a Commercial Motor Vehicle on an interstate (traveling between two or more states). This applies to ALL classes.
In addition to the CDL classes, there are also special endorsements and restrictions that you must have to drive certain types of commercial vehicles. They are:
Endorsements/Restrictions
Endorsements The following authorizations are required when operating vehicles of the type listed:
H - Required to drive a vehicle with hazardous materials placards (you must be 21 years of age).
N - Required to drive a tank vehicle.
T - Required to drive double and triple trailers.
P - Required to drive a vehicle designed to carry 16 passengers or more including the driver (buses).
S - Required to drive a school bus. Designed to carry 11 passengers or more, including the driver.
X - Represents a combination of the hazardous materials and tank vehicle endorsements (you must be 21 years of age).
Restrictions The following restrictions prohibit you from operating certain type vehicles:
L - Restricts the driver to vehicles not equipped with air brakes.
B - Passenger endorsement restriction cannot drive Class A buses.
C - Passenger endorsement restriction cannot drive Class A or B buses
Then Tinmans post here is wrong because it says a Commercial or Non-Commercial Class A is required when towing a trailer of more than 10K. It also says a Class B is limited to a 10K trailer and be under 26k GCVWR. I don't see anywhere that anyone with a regular or class B license can tow a trailer over 10k. Maybe PA laws have changed like NY did in 95.
/ Towing 14K trailer #50
CLASS A: A Class A license is issued to those persons 18 years of age or older who have demonstrated their qualifications to operate any combination of vehicles with a gross combination weight rating of 26,001 pounds or more, provided the gross vehicle weight rating of the vehicle or vehicles being towed is in excess of 10,000 pounds.
You have to included the word in bold red when you read it:)
/ Towing 14K trailer #51
I'm confused since what you just posted above agrees with what I've been saying all along. that PROVIDED the vehicle OR vehicle being towed is in excess of 10K you need a CDL class A. I can't see anywhere where it says you can tow a vehicle over 10K without a CDL A. Sorry, maybe I need new glasses.
/ Towing 14K trailer #52
CLASS C (minimum age 18): A Class C license is issued to those persons 18 years of age or older who have demonstrated their qualifications to operate any single vehicle with a gross vehicle weight rating of not more than 26,000 pounds or any combination of vehicles, except combination vehicles involving motorcycles, that does not meet the definition of a Class A or Class B vehicle. Where required, appropriate endorsements must.
I re-read this part for PA class C which can be interpreted as what you are saying that any combination of vehicles up to 26K. If this is the case you are correct and I am wrong. My apologies. I guess anyone would have to be a Philadelphia lawyer to interpret the way these laws are written in any state and I am not one.
/ Towing 14K trailer #53
No problem George
This is the way that i read it for years ( because that is how a friend of mine explained it to me) until it was pointed out to me correctly. Many, many people including some DOT guys read it the same way you did.
It is pratically the same wording as the federal requirements.
The Class C is for vehicles that otherwise don't require a CDL but do now because of things like HazMat
/ Towing 14K trailer #54
Don, did you even read your own link that you posted? It doesn't say anything about needing a CDL, it is about new inspection requirements.
Here is the book for Conneticut (Page 11/ section 1.1)
http://www.ct.gov/dmv/lib/dmv/20/29/comdr.pdf
Here is the book for Mass ( Page 5/ Section 1)
http://www.mass.gov/rmv/cdlmanual/CDL_Manual_Part_1.pdf
Here is the book for Montana (page 2)
http://www.doj.mt.gov/driving/forms/25-0300.pdf
This will make it a little easier
I realize it says Maine but it is the same for most of us
Note that the Mass CDL book you cited is a generic one and carried a note on page 5 saying "your state may have additional definition of CMVs." Page 7 warns that you have to have a CDL to drive a CMV. Mass Law by law included section 390.5 of 49CFR which gives this definition:
Commercial motor vehicle means any self-propelled or towed motor vehicle used on a highway in interstate commerce to transport passengers or property when the vehicle
(1) Has a gross vehicle weight rating or gross combination weight rating, or gross vehicle weight or gross combination weight, of 4,536 kg (10,001 pounds) or more, whichever is greater; or
So if the DOT cop knows the Mass laws, they can ticket and put you out of service in a 10K+1 vehicle for failing to have a CDL if you are using your truck/trailer in commercial use. Their inspection rules fall in the 49 CFR definition.
/ Towing 14K trailer #55
(Not a lawyer, but I've spent a bit of time researching this as I'm a MA resident w/ a 12k trailer & no CDL).
Section 390.5 of 49CFR is simply defining a commercial vehicle, and the MA definition in 90f referring to it only for the purposes of 'section 9', which largely has to do with drug & alcohol & other violations. IE, a CDL holder getting in trouble in a lesser commercial vehicle can get his ticket pulled.
Section 5, which prohibits the driving of a CMV w/o a CDL would not include the additional definition from 390.5 of 49CFR in its restrictions.
Full text of Section 9: M.G.L. - Chapter 90f, Section 9
-mike
/ Towing 14K trailer #56
-mike
Welcome to TBN MogginMike
Excellant first post:)
One question though, is yours a CMV?
/ Towing 14K trailer #57
The Putnam XDR line of 2" solid steel ball mounts are rated for 15,000.
Putnam
/ Towing 14K trailer #58
Putnam
X2
I have a Putnam 15K hitch on mine. Overkill, since I'm only 12K on the bumper, but that's what my Reading truck body installer puts on 'em.
I highly recommend them. Very sturdy American made stuff.
/ Towing 14K trailer #59
Overkill is always a good thing with trucks and trailers IMO.
I have a 15k rated ball mount I ordered several years from a company in Chicago that forged them out of one piece, it appears that they are now out of business.
I had bought a new 14k rated dump trailer and had a very difficult time finding a rated towbar for it back then....
/ Towing 14K trailer #60
I just want to throw this out there, many of the manuals state that in order to tow over 5000lbs and 500lbs tong weight you need to use a load distributing hitch, unless of course you are using a fith wheel. Now this is in the manual and labeled on my hitch, of course the GVWs are all on the door.
2020 CATERPILLAR 316 FL EXCAVATOR (A65056)
2020 CATERPILLAR...
PALLET OF METAL BRACKETS (A68842)
PALLET OF METAL...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
2012 TYTAL (A67714)
2012 TYTAL (A67714)
Skidded Fuel Cell (A67714)
Skidded Fuel Cell...
2013 Volkswagen Passat Sedan (A66738)
2013 Volkswagen...
