tow strap or chain?
/ tow strap or chain? #41
<font color="blue"> 2 half hiches </font>
Could you either tell or show me what you mean? I'm not familiar with the term as it was used here. Thanks. /forums/images/graemlins/smile.gif
Kudo's for passing along the excellent advice on using an attachment point below the center of the rear axle. Hooking above it can bring the front end up and over on top of you in something under 1 1/2 seconds! /forums/images/graemlins/shocked.gif It happens exactly that quickly. Be careful out there.
/ tow strap or chain? #42
I would be happy to show you, but I will need a day or so to get this together.
I will try and get a good scan and attach it.
/ tow strap or chain? #44
Re: tow strap/choker strap??? or chain?
sendero (or anybody):
In reading this thread, there is no discussion of the type of straps referred to. Are you folks talking about straight strap, or choker straps (used, among other things, for lifting steel at construction sites)?????
Personally, I don't like straight strap even if rated high enough. Somehow, chain seems stronger even if it isn't. But I do like choker straps as they seem VERY strong (although they fray easy).
Anyway, are you guys talking about straight straps or chokers???
JEH
/ tow strap or chain? #45
I use 1/4" grade 70. It is light and easy to handle. low quality 3/8 chain is about the same price as top end 1/4" chain, but is much heavier.
I can easily break cheap 1/4" chain. No damage to the grade 70 yet.
Kubota M6800, 4wd
2020 BOBCAT E55 EXCAVATOR (A59823)
2020 BOBCAT E55...
Bobcat A770 (A60462)
2011 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2011 DRAGON 150...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
Oxy-acetylene Torch and Regulator Rig (A61307)
Oxy-acetylene...
