Tough little dirtbucket with teeth!
   / Tough little dirtbucket with teeth! #1
jimgerken
Minnesota
John Deere 3720
After battling with the big 62" wide standard bucket on my little John Deere 4100 with 410 loader for a few years, I decided I needed a smaller and tougher tooth-equipped bucket. Went out and found locally the 2-part digging teeth.
...And then bought the right cutter bar for the teeth, and got the stock for the bulk of the bucket too.
This stock was too much for my bending equipment, being 10 gauge (0.135"), so I took it to a local shop and had the bending done. Here you see the bent result, setting next to the stock bucket, which I am sort of copying.
Then I layed out the side panels and cut them with the plasma cutter, of 3/16" steel.
...and began tacking it all together...
detail shot.
Lathe turned the pins for the quick-attach feature, and TIG welded them to some mounting plates.
Then I fabricated the upper mounting bracketry. These gussets were also plasma cut.
Rear side view, bucket basically completed. I still have to weld on the teeth, to do this weekend.
Not shown details include two seperate torsional-strength adding elements welded in. One in back lower corner, one in the inside top.
   / Tough little dirtbucket with teeth! #10
Afternoon Jim,
Very nice job !!! What size is the new bucket ? I read that the other bucket was 62", just curious what size this is ? The fabrication was super !:)
2016 Ford F-550 4x4 Bucket Truck, VIN # 1FDUF5HT8GEB70191 (A51572)
2016 Ford F-550...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
Kubota RTV-X1100C (A51573)
Kubota RTV-X1100C...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2014 KOMATSU PC490 LC-10 CRAWLER EXCAVATOR (A52576)
2014 KOMATSU PC490...
