Torque Specs
/ Torque Specs #1
carpetfarmer
Ford 2N
My dad is working on a YM2000 with a major oil leak out of the starter. I posted on here some time ago about this same problem, but we are just now getting the opportunity to start working on it. The problem is, he can't find the torque spec. for the flywheel or the rear seal plate behind the flywheel. Could any of you help us out?
/ Torque Specs #2
Sorry I can't be more specifically helpful, but can you look up the standard torque range for the size/grade bolt you're dealing with? I don't really know what I'm talking about so I apologize if this isn't helpful at all.
xtn
/ Torque Specs #3
I believe the flywheel nut should be 275 - 304 ft lbs. Not sure about the seal plate bolts but I think you will find them to be 10mm and I doubt a high grade. My best guess without identifying the bolt grade would be 35 - 40 ft lbs.
/ Torque Specs
Thank you for the help, I will pass it along.
2012 International DuraStar 4300 Digger (A62613)
2012 International...
Caterpillar Standard Job Description Manuals (A63117)
Caterpillar...
2015 Teupen TL54J Crawler Articulating Boom Lift (A61572)
2015 Teupen TL54J...
2013 Chevrolet Silverado Service Truck (A62613)
2013 Chevrolet...
2017 Dodge Grand Caravan Van (A61574)
2017 Dodge Grand...
2015 International ProStar T/A Wet Kit Day Cab Truck Tractor (A61573)
2015 International...
