Torque Specs
/ Torque Specs #1
carpetfarmer
Ford 2N
My dad is working on a YM2000 with a major oil leak out of the starter. I posted on here some time ago about this same problem, but we are just now getting the opportunity to start working on it. The problem is, he can't find the torque spec. for the flywheel or the rear seal plate behind the flywheel. Could any of you help us out?
/ Torque Specs #2
Sorry I can't be more specifically helpful, but can you look up the standard torque range for the size/grade bolt you're dealing with? I don't really know what I'm talking about so I apologize if this isn't helpful at all.
xtn
/ Torque Specs #3
I believe the flywheel nut should be 275 - 304 ft lbs. Not sure about the seal plate bolts but I think you will find them to be 10mm and I doubt a high grade. My best guess without identifying the bolt grade would be 35 - 40 ft lbs.
/ Torque Specs
Thank you for the help, I will pass it along.
2017 FORD F-350 SUPER DUTY (A65643)
2017 FORD F-350...
2018 INTERNATIONAL LT DAY CAB TRUCK TRACTOR (A67147)
2018 INTERNATIONAL...
INSPECTION (A65579)
INSPECTION (A65579)
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
2019 DODGE RAM 1500 (A65643)
2019 DODGE RAM...
2015 JET 42' ALUMINUM HOPPER BOTTOM TRL (A64277)
2015 JET 42'...
