Torque RPM?
/ Torque RPM? #11
HP = Torque X RPM / 5252. see link. The diagram above shows the F2803 engine making 155 ft-lb at 1650 rpm or about 49 hp, plenty for many jobs.
Yes, I'd say both are correct in their own context. You wrote your definition as a formula using mathematical notation. When using such formal notation it is quite correct to include constants.
My goal was a little different. I wanted to use a conversational format to show in an informal and non-mathematical way how even an obscure term like "torque RPM" can still contain the basic things we need to consider for calculating horsepower.
thank you,
rScotty
/ Torque RPM? #12
One thing to avoid for good engine health is bogging down/stalling. The journal bearings hate to run at low speed & high torque conditions, due to a breakdown in the hydrodynamic film thickness. As the film thickness is reduced, metal to metal contact between the high spots starts to occur, causing increased heat and wear.
Looking at the characteristic curves supplied by rbargeron, maybe try running the engine at a higher speed than you have - say 1800 - 2000 RPM, even if you don't need the HP or torque. My reasoning is twofold:
First, as jaotguy noted, the water pump will be doing a better job getting the heat out of the engine and into the radiator. A well cooled engine is a happy engine.
Second, as rbargeron notes, the engine torque curve has a peak at the low end. This can be used by an operator to good advantage by taking note of engine speed in response to increasing load. As engine speed starts to drop off, torque increases and the engine can maintain the load. After the engine passes the point of max torque, though, increasing load will rapidly bog down the engine. Running well above the peak gives you time to react to increasing load and decreasing engine speed before the engine bogs down or stalls. Your journal bearings will thank you.
SKID MOUNTED CONTAINMENT (A58214)
SKID MOUNTED...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
2006 TAKEUCHI TB135 EXCAVATOR (A62129)
2006 TAKEUCHI...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
JLG 3246ES ELECTRIC SCISSOR LIFT (A59823)
JLG 3246ES...
2019 KUBOTA SVL95-2S SKID STEER (A62129)
2019 KUBOTA...
