Mowing Torque Bush Hog Blades
   / Torque Bush Hog Blades #1
srcaaga
Shipman, Virginia
Kubota MX 5000, Gravely Promaster 60, Gravely 546, Gravely 5265
I have a Howse 6FT bush hog and the manual does not indicate the bolt torque for the blots attacting the blades to the circular "stump jumping" plate. Any suggestions woold be appreciated.
   / Torque Bush Hog Blades #3
1000ft-lbs is about right.
1000 or did you mean 100? Thanks.
   / Torque Bush Hog Blades #5
I think theyre 1" high grade fine thread. Depending on bolt Grade, bolt torques on that size range up to more than 1000. Gr 5 is about 600. Gr 8 is about 1000. I would not go less than the Gr 5 torque recommendation for the diameter the bolts are. Measure them and go from there. ... or just hammer the heck out of them with a strong 1/2" impact gun. That might leave them just a little on the loose side.
larry
   / Torque Bush Hog Blades #7
I use a 1" ratchet set and a 6 foot bar on the ratchet handle. I put both arms into it. A 1/2" rattle gun is not going to do it, and them bolts are expensive, so don't risk losing one!
2007 International 7400 Chassis Truck, VIN # 1HTWGAAR87J437650 (A51572)
2007 International...
Swict 72" Bucket (A50121)
Swict 72" Bucket...
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
2000 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
2000 Mack CH613...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
2019 John Deere 6175M (A50120)
2019 John Deere...
