Mowing Torque Bush Hog Blades
/ Torque Bush Hog Blades #1
srcaaga
Shipman, Virginia
Kubota MX 5000, Gravely Promaster 60, Gravely 546, Gravely 5265
I have a Howse 6FT bush hog and the manual does not indicate the bolt torque for the blots attacting the blades to the circular "stump jumping" plate. Any suggestions woold be appreciated.
/ Torque Bush Hog Blades #3
1000ft-lbs is about right.
1000 or did you mean 100? Thanks.
/ Torque Bush Hog Blades #5
I think theyre 1" high grade fine thread. Depending on bolt Grade, bolt torques on that size range up to more than 1000. Gr 5 is about 600. Gr 8 is about 1000. I would not go less than the Gr 5 torque recommendation for the diameter the bolts are. Measure them and go from there. ... or just hammer the heck out of them with a strong 1/2" impact gun. That might leave them just a little on the loose side.
larry
/ Torque Bush Hog Blades #7
I use a 1" ratchet set and a 6 foot bar on the ratchet handle. I put both arms into it. A 1/2" rattle gun is not going to do it, and them bolts are expensive, so don't risk losing one!
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
Mini rock grapples (A61567)
Mini rock grapples...
2025 SDLGC100 6 Passenger Electric Cart (A60352)
2025 SDLGC100 6...
2022 Horizon Trailer (A55973)
2022 Horizon...
2014 Vermeer Vac-Tron MC533SDT Heavy Duty Vacuum Trailer (A60352)
2014 Vermeer...
2022 Horizon Trailer (A60352)
2022 Horizon...
