Toro 824 Snowblower Slightly Modified.
/ Toro 824 Snowblower Slightly Modified. #1
kdlklm
Saskatchewan, Canada
Kubota BX1830
I acquired a Toro 24 inch snowblower with a blown engine. I happen to have one sitting around that was slightly larger than the 8.5 horsepower that was on it previously. It's a 13 horsepower Kawasaki. It weighs probably 100 + pounds more than the previous engine and more than twice the size. The original pulley wouldn't fit the new motor, and I didn't feel like running around finding one the same size, so it's a little bigger. Increasing the gear ratio by almost double. It will throw some snow about 60 feet. The muffler is also blown out. So it's a little bit loud. The extra weight is really nice for heavy snow. It just walk straight through it and fast. It's also the only snowblower I have seen with a battery. Which is nice now that I blow all the neighbors yards out to. I get quite the reactions, so I thought I would share this with you.
before
/ Toro 824 Snowblower Slightly Modified. #3
Can you say aarrhh!aarrhh! What a unit? this would make tim the toolman taylor envious!!! 60 feet huh? watch-out for rocks you may end up buying a windsheild or two??
Hey wait till the snowplows are coming by to block your driveway(again) and blow it back all over their trucks /forums/images/graemlins/grin.gif(sweet )
another
/ Toro 824 Snowblower Slightly Modified. #5
Impressive looking machine, I've got a Craftsman 5 hp 24 inch dual stage blower that could use a few more hp, I will keep your idea in mind. Question, did you get the idea for the engine swap after watching the movie "Lawnmower Man"...?
/ Toro 824 Snowblower Slightly Modified. #6
Not sure how I came across this but that is the way to upgrade !! Push button start and weight on the front and over the wheels !!
HYDRAULIC AUXILIARY TRANSMISSION (A65643)
HYDRAULIC...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
2001 INTERNATIONAL 4700 4X2 S/A UTILITY BODY TRUCK (A66091)
2001 INTERNATIONAL...
2020 JOHN DEERE 770G MOTORGRADER (A63276)
2020 JOHN DEERE...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
