Toro 580-D
/ Toro 580-D #1
LittleBittyBigJohn
Central Arkansas
John Deere 1025R, Kubota ZD1211
I have been looking for a bigger mower for my new property. I was not specifically looking for a wide area mower but I came across this one. Best I can tell it's a Toro 580-D 16' cut and 80hp Mitsubishi Turbo Diesel. Made from late 80's to the early 00's. Owner got it in an auction lot. Started it with a jump box and had to chase it when it started driving away on it's own. He said it has "wiring problems" and that you can see where some wiring was burned. That is all the info he has on it and does not want to mess with it. Anyone have any experience with these?
It's priced low enough that it's almost worth the risk. It's about a 3 hour drive for me so I can't really just run over quickly to check it out. Looks like it takes 2 batteries and there are none on board. You recon jumper cables from my truck would work to start it? I'm not too worried about the flat tires or what looks like at least 1 bent blade.
/ Toro 580-D #3
Not even an hour between posts, that was fast! What a shame, that Toro could have been fun.
Land honor Mini Skid Steer (A60352)
Land honor Mini...
2004 Quincy QSI500 Air Compressor (A61572)
2004 Quincy QSI500...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A59823)
2018 FREIGHTLINER...
2018 CARLTON 660 TOWABLE WOOD CHIPPER (A64279)
2018 CARLTON 660...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
