Torn between buying an SA324 and a YT235
   / Torn between buying an SA324 and a YT235 #1
STxGardener
N/A
The jobs that I HAVE FOR THE YANMAR THt I end up buying are on the light side but I willl likely buy a 5' Ironcraft Titan tiller to till a garden. two or three times per year. I will also use the tiller to move dirt around and to turn and mix compost piles. So my dealer is confident that the SA324 can do what I want but I think it will be tough on the tilling as we have hard clay here. I plan on conditioning the soil with compost so it may get better over time.
So with all of that said I also think about the resale value of the tractor in I need to sell it in a few years. I like the overall quality of the YT235 and it seems to be more like a "real" tractor as compared with the SA234. As far as I can tell the cost difference between the two as equipped would be around $9K, so that difference definitely factors into the decision but I may pay the extra dollars for a much better tractor and better resale value. Keeping $9K would be nice also...lol.
Any thoughts or comments on my purchase would be greatly appreciated. By the end of this week I should own one or the other. Thanks.
   / Torn between buying an SA324 and a YT235 #2
I think, this time salesman is not wrong
Tillers are not asking for a lot of HP. 25 horses will do the job
Maybe 1 1/2 minutes longer than more powerful sibling. But if you are looking to do the job 2 times / y it should not have any impact on your decision
Smaller is more agile, dont compress soil
Thanks, I didn't consider the soil compression from the weight difference. I am retired so as with most retirees I'm never in a hurry.
   / Torn between buying an SA324 and a YT235 #4
I am happy owner of SA424
If you mention "garden", I meant, that's the right size
But obviously I don't know, what kind of garden you have and what you want to do there
   / Torn between buying an SA324 and a YT235 #5
How big is your garden? Haven't used a PTO driven tiller, but I'm wondering if 5' is a bit much for a 25hp size tractor in hard clay unless you till in very limited depth?
I am just planning a simple vegetable garden that will end up being less than 5,000 sq. ft. altogether., (probably closer to 3,000 sq. ft. to start with. I am going to take down some raised 3 ft high garden boxes that I built ten years ago that are falling apart. I will probably convert those boxes into a 10 ft x 100 ft. garden plot also.
Thanks for all of the comments. I am feeling better about the SA324.
   / Torn between buying an SA324 and a YT235 #7
A smaller tractor would be easier to manuever in a small garden, but I'm not sure about the 5' tiller versus a 4'. Compost will make the soil much easier to till over time.
I am not worried about maneuverability because I am basically tilling out my front lawn that is about 1/3 of an acre in size. It will be a very open garden.
The comments suggesting a 4' tiller rather than a 5' tiller are probably spot on but the rear tires are over 48" wide so I wanted to cover my tracks. I guess I can go about it a little at a time and take on more depth as I till it with more passes. The tilling made me think that I might need the bigger tractor. I think that the YT235 would have a much better resale value but it would probably be overkill for my needs. Decisions, decisions.
   / Torn between buying an SA324 and a YT235 #10
Do you have other uses for the tractor?
A 35hp tractor will have a DPF emissions system. I imagine it will also lift more dirt in the bucket if that's a concern.
A 25hp tractor may be able to run a 5' rotary cutter where 35hp may be able to run 6' in the same conditions.
edit: how do you plan to cultivate your garden after the plants start growing?
I plow my garden with the tractor in the spring, but use a Troy Bilt walk behind tiller for cultivation myself. I have other uses for the tractor, but I couldn't justify owning a tractor if all I did with it was to plow the garden once in the spring.
2017 Chevrolet Impala Sedan (A56859)
2017 Chevrolet...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A56857)
2017 JLG Skytrak...
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
2016 Ram 4500 Wrecker/Snatch Truck, VIN # 3C7WRKAL4GG243467 (A57453)
2016 Ram 4500...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2003 INTERNATIONAL 9900I (INOPERABLE) (A58214)
2003 INTERNATIONAL...
