Torch problem
/ Torch problem #21
I bought a bunch of torch stuff at an auction five or so years back. Finally got one of those scrappers torches three feet long. that I always wanted and have little need for. But it's BOSS! Works good! Now I can put on my shorts and flip-flops and cut apart Ships! What didn't work so good was a regulator that burst one of my better hoses!
/ Torch problem #22
Burst hose? :eek:
/ Torch problem #23
Yeah. Regulator wasn't doing it's job.
/ Torch problem #24
The guy on I C Weld uses a shorter but still long cutting torch than Industrial Toys, for field repair. I don't think it's a scrapper's torch. If anyone knows why it's as long as it is, please let me know.
/ Torch problem #26
A typical setting (and a good starting place) for Acetylene is 7 lbs and Oxygen 14 lbs. If the torches have been sitting for a time it may be necessary to purge the air out of the lines first - the longer the hoses the more of an issue is since there can be a significant amount of air in the lines. When you purge the acetylene hold the tip where you can see across the tip. When acetylene starts to come out you can actually see the "invisible" gas as it distorts the air. When both are purged try lighting and see how it works. Sometimes that gland nut (under the valves on the torch body) will loosen and the valves will turn too easy or respond to being bumped. Tighten these down a BIT - not real tight - and the torch will hold the valve position better.
/ Torch problem #27
you're very lucky it wasn't the acetylene regulator that failed, that would cause a huge explosion!.. acetylene self explodes I believe at 18 psi..
So, how you figure dat pocket of acetylene between top of filler in tank and valve not blow up since it above hundred pound pressure?
/ Torch problem #28
I used to siphon (not really the right word) off half a bottle or so of acetylene from friends tanks who had a contract. I still have the hose assembly. Funny how old timers just knew their way around things. Nowadays everything is just ready to explode if you don't abide by SOPs.
This was offered up to my on YT/Apple TV yesterday. Kind of Interesting.
Danger of Gas Cylinders �� We will show you their power / Stay safe - YouTube Kind of funny. Video about safety. Never mind sideswiping something with the cylinder on the bike and shearing off the valve.
I kind of wish my various cylinders were nowhere near my buildings, never mind inside. But that's highly impractical.
Oh, Long Torch is nice for cutting stuff apart. Not so much bending down and you are not so close when stuff spits back at you.
/ Torch problem #30
the secret is acetone!..
Really? Do tell how dat works.
While you at it splain why city of Speedway Indiana exists.
Dey interrelated.
Maybe you can tell bout de dual carbon bond in Acetylene and how dat comes apart all by itself and causes BOOM.
IT, word you huntin is Cascade. Been doin it long time wid Propane, Argon, Co2, Nitrogen & Helium, even know enough to not hotshot bottle. Talkin to old goat at supply house one time bout doin to fill MC bottles. He points out few things to me bout Acetylene includin how dey don't do in house, and says I insist let him know so he can come and watch, thru binocular glasses from long way back. Decided maybe he right. New fill plants pretty darn smart, can almost overcome dumb bottle wrestler.
/ Torch problem #31
We did it maybe three times. I was always worried about the acetone aspect of it. As in I didn't have a clue what that was all about. Just knew that WELDING GAS companies made it financially impossible to buy gas for occassional/private use.
The term CASCADE would imply to me running several tanks together as I see with certain CNC cutting machines. But all put in full and removed at the same time. Not much differential between them. I don't know what sweat more. The cylinder or me.
/ Torch problem #32
Acetone de problem for sure. You gotta know tare weight of receiving cylinder wid Acetone in place or you can get in trouble. Fill plant add acetone if needed before pumping in Acetylene. You can also get in deep if big bottle shoots acetone into receiving bottle. Gas flow rate gotta be governed to prevent.
Cascade = multiple large bottles going into small bottle. Small bottle @ 0 to begin you fill from big wid lowest pressure till equal, den switch to filling from bottle wid next highest pressure until small bottle at full pressure. Works OK but time consuming. Gotta go slow so small bottle don't hotshot. Moving gas at pressure generates lot of heat. Hotshotted small bottle can show 2000 but only be half full by weight. When it cools will show 1000-1200.
You look at gas invoice it says XXX cubic feet pumped to 2200psi @ 70° or such. Different for Co2 and Propane sold by de pound or gallon.
6pac and 12 pac multiples you see on CNC just group of bottles, usually 330s plumbed to a manifold. You can cascade off 1 if you know how, PITA if individual bottle valves not normally operated. You try transfill off pac wid all valves open small bottle usually hotshots fast and way short of capacity.
Rac really old school been around since 50s. You usin dat much gas you better off running Dewer of LOX. Problem wid LOX is expansion loss over time. Scrap cutters love dewer wid 100 pound propane. Fill up Monday morning and cut most of week. Refill next Monday. Best if you cut 12 or 16 hours a day.
Whole lot of hotshotting playing out on guys buying gas from small vendors who fill customer owned tank while you wait. Takes over an hour to fill a 40cf by cascade minimum.
Cascade breathing air fillers real dirty salesman game on rural fire departments. Sounds good, looks good on paper, not worth squat when installed.
/ Torch problem #33
The term CASCADE would imply to me running several tanks together as I see with certain CNC cutting machines. But all put in full and removed at the same time. Not much differential between them. I don't know what sweat more. The cylinder or me. it used to be recommended to only use 1/7 of the tank capacity, now, they recommend to only use 1/10 of the tank capacity to prevent the loss of Acetone, which means that a 390 CUFT WTL tank) Acetylene tank is on the very low side of being able to weld/cut 3/4" steel!!..
/ Torch problem #36
It was always a let down going from acetylene to propane. Acetylene burned so nice and hot. But i get the propane, heck of a lot cheaper.
There is some interest in using propylene instead of propane or acetylene (cheaper then acetylene), but it requires "T" rated hosed and propylene rated nozzles and tips.. Debated it with others on a welding site and decided to just bite the bullet and stay with acetylene and use propane as a back up if out of acetylene...
Dale
/ Torch problem #37
Dale
with Propane, you need to use flux coated rods, or powder flux, as there is no shielding effect with Propane!..
/ Torch problem #38
Yeah, but I do very little gas welding, torch is mostly for heating and bending and cutting, for most welding I use MIG.... Maybe one time in 2-3 years I need to braze something... Am aware of lacking gas bubble shielding effect (forget proper terminology) not being there with propane for gas welding but is there with acetylene....
Dale
/ Torch problem #39
I use 5 acy. and 10 oxy. I will never go to propane! ---saw it being used and WOW! what a mess it makes!lol!
/ Torch problem #40
You are supposed to use T hose with all alternate fuels. Funny they made it this far using regular R hose since the beginning of time.
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2022 Ford Explorer AWD SUV (A59231)
2022 Ford Explorer...
2010 Ford Fusion Sedan (A59231)
2010 Ford Fusion...
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
S/A Fuel Tank Trailer (A59231)
S/A Fuel Tank...
