Topper aft wheel?
/ Topper aft wheel? #1
Anonymous Poster
Epic Contributor
Hi all sorry for this newbie question but I need to know what the rear wheel actually does? I have just bought a 4' topper (brush hog as you call it) this model to be precise (SG 120)
http://www.suire.com/img/machines/stargreen.jpg
It has a rear wheel as an optional extra. I cut 5 acres of mostly level paddocks, however I do have a few banks and unlevel bits to cut also and I have to do quite a lot of sharp turns. Do I need the wheel?
Thanks in advance
Drew
/ Topper aft wheel? #2
The rear wheel is quite useful for maintaining an semieven cut over even slightly uneven terrain.
/ Topper aft wheel? #3
Need it? No. Want it before you try bush hogging the second time? YES!
/ Topper aft wheel? #4
Without a rear wheel, when you start up an incline, the rear of the cutter will hit the ground and the blades will most likely gouge out an area of turf. The rear wheel helps maintain a more level cut.
/ Topper aft wheel? #5
Thanks guys, I will be adding one soon I think, even if it is £130 :(
2018 VOLVO VNL TANDEM AXLE DAY CAB (A59912)
2018 VOLVO VNL...
1996 International Water Truck with a Caterpillar Engine (A63688)
1996 International...
POLY TOTE W/ CAGE (A63291)
POLY TOTE W/ CAGE...
2019 INTERNATIONAL LT625 T/A 6X4 SLEEPER TRUCK TRACTOR (A59912)
2019 INTERNATIONAL...
3012SFL (A61567)
3012SFL (A61567)
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
