Top Speed
/ Top Speed #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
The B9200 Kubota owners manual lists a top speed with the HST (hi range)and 13.6-16 rear tires of 11.72 MPH @ 2500 engine RPM. I'm curious why, when top engine RPM is 3000, would Kubota not show the max speed of 11.74 times 3000/2500 or 14.09 MPH.
/ Top Speed
I wonder if was an attempt on the part of Kubota to limit liability.
/ Top Speed #4
breaking power when fully loaded down perhaps? max speed with max load on it?
is 2500 RPMs high green side of RPM gauge. and 3000 RPMs red lining the RPM gauge?
is 2500 RPMs suggest RPMs for 540RPMs at PTO shaft or 1000RPMs at PTO shaft? and they just went with keeping things simple for wanted RPMs at PTO shaft for various 3pt hitch equipment?
/ Top Speed #5
2500 rpm at this particular Kubota engine is so called rated speed. If you investigate power, torque and specific fuel consumption curves you will see that it is a speed around which the tractor has the highest torque and the lowest specific fuel consumption [g/kW/hour or oz/HP/hour]. In other words that is the speed range where the tractor is most efficient.
2017 Ram 5500 Bucket Truck (A63689)
2017 Ram 5500...
2020 Freightliner 114SD T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A61573)
2020 Freightliner...
Kubota V3600-T Turbo Diesel Industrial Engine  63kW (84 HP)  2016 Model  Pump Takeout (A63689)
Kubota V3600-T...
UNUSED 4' X 300' ROLL ATS POWER GRASS PROOF CLOTH (A64281)
UNUSED 4' X 300'...
2022 John Deere 325G Track Loader (A63111)
2022 John Deere...
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
