Top speed - 1972 Case 580CK
   / Top speed - 1972 Case 580CK #1
sweetjeep
Hey folks,
I have a '72 case 580 CK. New to me. It's a hydro drive beast and, unless I am missing something. It's god awful slow.
By which I mean: I don't appear to have any 'range' selections. Just the forward and reverse pedals. There is a creeper/"cruise" lever on the steering column which works, but I am not counting that.
As for the speed.. I'd say that at roughly half throttle full speed is basically a quick walk.
Is this correct? Normal? Am I missing something?
The only other item of note is a black knob on the lower left of the dash labled "shift speed" or something similar. But it doesn't appear to do anything.
Thoughts??
thanks!
Morgan
   / Top speed - 1972 Case 580CK #2
sounds like the range lever got disconected.
I doesn't make sense that it would be that slow normaly, you might as well have tracks if thats the top speed.
Where is the range lever? It's quite possible I haven't even seen it yet! I have very little time on the machine and until now, haven't needed it to go any faster.. I just sort of assumed it would go when I pushed down more..
I bought it basically just for the backhoe but I do need to transport it about a mile and a half from time to time.
   / Top speed - 1972 Case 580CK #4
FIL has a '77 that has the range lever located at your feet, nearly under the seat.
I believe it has 3 ranges...
Hope this helps.
Lunk
It might! :) There is a lever down there that doesn't appear to have a purpose!
I'll look around a bit and see what I can find.
Thanks!
2025 Big Tex 14GN-40D5A 35ft 6 Ton Gooseneck Flatbed Trailer (A51692)
2025 Big Tex...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2025 K1230 UNUSED (10) Wire Mesh Netting Rolls (A53117)
2025 K1230 UNUSED...
2017 Ford F-350 Crew Cab Service Truck with Liftgate (A51692)
2017 Ford F-350...
SET OF (4) BRAND NEW CHAINS AND BINDERS (A53843)
SET OF (4) BRAND...
2017 Ford Taurus Sedan (A51694)
2017 Ford Taurus...
