Top speed - 1972 Case 580CK
   / Top speed - 1972 Case 580CK #1
sweetjeep
Hey folks,
I have a '72 case 580 CK. New to me. It's a hydro drive beast and, unless I am missing something. It's god awful slow.
By which I mean: I don't appear to have any 'range' selections. Just the forward and reverse pedals. There is a creeper/"cruise" lever on the steering column which works, but I am not counting that.
As for the speed.. I'd say that at roughly half throttle full speed is basically a quick walk.
Is this correct? Normal? Am I missing something?
The only other item of note is a black knob on the lower left of the dash labled "shift speed" or something similar. But it doesn't appear to do anything.
Thoughts??
thanks!
Morgan
   / Top speed - 1972 Case 580CK #2
sounds like the range lever got disconected.
I doesn't make sense that it would be that slow normaly, you might as well have tracks if thats the top speed.
Where is the range lever? It's quite possible I haven't even seen it yet! I have very little time on the machine and until now, haven't needed it to go any faster.. I just sort of assumed it would go when I pushed down more..
I bought it basically just for the backhoe but I do need to transport it about a mile and a half from time to time.
   / Top speed - 1972 Case 580CK #4
FIL has a '77 that has the range lever located at your feet, nearly under the seat.
I believe it has 3 ranges...
Hope this helps.
Lunk
It might! :) There is a lever down there that doesn't appear to have a purpose!
I'll look around a bit and see what I can find.
Thanks!
UNUSED Artificial Turf Grass (A53117)
UNUSED Artificial...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A54607)
2015 VOLVO VNL...
2018 MDB LV600 GREEN CLIMBER SLOPE MOWER (A51406)
2018 MDB LV600...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51406)
2016 KENWORTH T270...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
2007 Mahindra 4110 Tractor (A53117)
2007 Mahindra 4110...
