Top speed - 1972 Case 580CK
/ Top speed - 1972 Case 580CK #1
sweetjeep
Hey folks,
I have a '72 case 580 CK. New to me. It's a hydro drive beast and, unless I am missing something. It's god awful slow.
By which I mean: I don't appear to have any 'range' selections. Just the forward and reverse pedals. There is a creeper/"cruise" lever on the steering column which works, but I am not counting that.
As for the speed.. I'd say that at roughly half throttle full speed is basically a quick walk.
Is this correct? Normal? Am I missing something?
The only other item of note is a black knob on the lower left of the dash labled "shift speed" or something similar. But it doesn't appear to do anything.
Thoughts??
thanks!
Morgan
/ Top speed - 1972 Case 580CK #2
sounds like the range lever got disconected.
I doesn't make sense that it would be that slow normaly, you might as well have tracks if thats the top speed.
Where is the range lever? It's quite possible I haven't even seen it yet! I have very little time on the machine and until now, haven't needed it to go any faster.. I just sort of assumed it would go when I pushed down more..
I bought it basically just for the backhoe but I do need to transport it about a mile and a half from time to time.
/ Top speed - 1972 Case 580CK #4
FIL has a '77 that has the range lever located at your feet, nearly under the seat.
I believe it has 3 ranges...
Hope this helps.
Lunk
It might! :) There is a lever down there that doesn't appear to have a purpose!
I'll look around a bit and see what I can find.
Thanks!
New/Unused Wolverine 72in Quick Attach Tiller (A61166)
New/Unused...
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
New/Unused Landhonor 11ft x 19ft Carport with Open Side Walls (A61166)
New/Unused...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
24in pin on excavator tooth bucket (A61307)
24in pin on...
