3-Point Hitch Top link mount tore off back of differential case
   / Top link mount tore off back of differential case #71
That's fair. I'd like to see the bolt/tapped hole on the other side though.
With a loose bolt, just the cantilevered weight of the bh driving down the road could reek havoc.
Eh, I think even one day outside in the rain after the failure could rust up those bolt hole threads. Note the bucket placed over the steering wheel and dashboard for rain protection.
   / Top link mount tore off back of differential case #72
Do you mean the bolt going straight down?
I've pulled the 3pt hat off a couple Kubota compacts and the through holes on the hat have always had some corrosion in them. Based on the corrosion on the 3pt balls etc. I'm guessing it lived outside for some of its life
With that wheel barrow tub over the operator controls I would say it's probably outside or it's shed kept and when it broke he put the tub on it to protect it untill it was moved? I would cover the open transmission area too but that if it was covered has been removed for a clear pic.
   / Top link mount tore off back of differential case #73
In the closeup on post #1, I'd like to see the bolt at the 7 o'clock position from the filler cap.
My thought on the rusted bolt hole was that on a really tight bolt, it would be hard for water to wick between the compressed, mating flanks of the 60 degree thread forms. Maybe on the non-compressed flanks though. That rust looks very scaly.
As far as that rust occurring after the accident, the adjacent broken casting is pristine.
   / Top link mount tore off back of differential case #74
Yup, even the time it spent on the dealers lot can cause that corrosion. The threaded area thats visible isn't rusted, only the through bolt hole.
   / Top link mount tore off back of differential case #75
I dont think any of that rust in the bolt hole happened after the break, non of the threaded areas visible have rust, just the through hole.
   / Top link mount tore off back of differential case #76
I actually just noticed something, there is a second pin in the top link bracket, with the larger solid top link of the BH I wonder if the BH top link bound on that second pin.
That could possibly put the full weight of the BH in a torsional load on the top link mount, which it is NOT designed to handle. One good bump and I could see it breaking if it didn't immediately. The way the casting is broken looks to support that type of loading.
I think you're on to something there. The top link has a visible shoulder, where the solid bar is welded to its rounded end. If there is the same shoulder on its underside, that lower shoulder could have jammed against the lower pin and not let the hoe go any lower. So instead of the 3-point arms supporting the hoe, that unintended contact carried all the weight. Then drive out to the worksite with that jammed surface carrying the weight of the hoe and lurch over a bump - and you have the forces to break something.
   / Top link mount tore off back of differential case #77
It does make sense. There is no lateral play on the that rigid top link. Along with the natural play of the lift arms, it allowed it to twist the top link mount like you said.
But in all honesty, that's an awful thin casting for all the stresses it has to handle. Even just roading the tractor and hitting a bump or something with a slightly heavier implement in the back, can possible cause damage to that.
   / Top link mount tore off back of differential case #78
For all we know OP didn't get to dig much with this and cracks might have begun just while driving with that much overhanging load. I'd sell the BH to pay for repair if I had to.
As a 20ph Terramite owner I kinda cringe when seeing smaller BHs on 40 hp machines that weigh 1 1/2 times as much. My T5C says 8' 6" depth and I've done 5'+ with ease trenching in for barn hydrants. Whole thing weighs < 3k lbs wet and will drive (snugly) through a 4' gate. btw, doesn't mean it won't stall leaning into big roots or rocks, and a ripper tooth is accessory-1 for many of us who are seriously digging vs dabbling.
Point is to support that BHs & bits made to do the work don't break. As for mounting one on a SSQA plate, what this did to the 3PH says I wouldn't want all that weight/load on my loader arms and I'd happily trade my skid-steer for a bigger Terramite. It's a bit late to suggest a boom & bucket SSQA option, and not all if us have a skidder.
btw, when one of our guys in OH lost an engine and had to spring out of pocket for a short-block he struggled to find at all I mentioned a crowd-fund. The idea fell flat, but I'm glad to hear that the spirit lives on. If we can't go back in time let's go forward.
   / Top link mount tore off back of differential case #79
If I understand this post mortem (2 pins in top link hole(s) caused a fulcrum/rotational situation) correctly, the top link on a 3pt BH is not functional like on any other attachment. There's a "stiffleg" that go's from the lower lift pins to the top link. Without this you would be unable to put the tractors weight down to the outriggers and would be relying on the BH weight ONLY to do all the digging, or it's no longer a parallel arms movement (lift arms and top link) as in a normal 3ph. You can see it in the first picture.
   / Top link mount tore off back of differential case #80
Wondering if anyone has experienced (prefer first hand; happened to your tractor) a top link mount being torn off the case of your tractor (any model or make).
I saw a L series Kubota one time that the top link tore open the case, even more than yours.
He had made a 3 point skidding attachment to pull logs out of the woods with and had a chain from it, to a bigger log. While pulling the log he heard a POP and it tore the azz of the tractor open.
My guess is, it cracked over time earlier, and got finished off that day... That's why I like the heavier/stronger castings of a farm tractor, a skidding winch would have helped him too.
You keep pulling on those thin castings, and sooner or later, something is going to give!
SR
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
2014 Ford F-550 (A55973)
2014 Ford F-550...
207279 (A52708)
207279 (A52708)
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A56438)
Case Wheels for...
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
