Toplink Top link attachment for maximum raised height?
/ Top link attachment for maximum raised height? #1
LGinIA
Iowa
JD X485 AWS,B2410,RTV900
There are two holes on m land pride implements to attach the top link and two holes on my B2410 for the top link attachment.
What is the proper attachment to get the maximum raised implement height?
Both top holes? Both bottom holes? What have you found to work the best?
Thanks
/ Top link attachment for maximum raised height? #2
Since you don't have draft control, just select the hole combination that renders the toplink closest to horizontal when the implement is in the working position.
Two holes in the Landpride suggests that you might be missing the flexible toplink bracket.
//greg//
/ Top link attachment for maximum raised height? #3
In addition to the above, the other consideration is draft load. Generally speaking, the higher the draft load the lower the holes desired.
/ Top link attachment for maximum raised height? #4
To get the max raised height, use the bottom hole on the B2410 and the top hole on the implement.
Joe
/ Top link attachment for maximum raised height? #5
For max height, I would suggest using a combination that keeps your top link and lower link arms parrallel. when horizontal.
/ Top link attachment for maximum raised height? #6
From the standpoint of simple geometry, that's backwards Joe. But the whole question is moot - since lift (and therefore height) is a function of the lower arms distance above and below horizontal. The toplink controls an implement's angle of attack by varying the distance fore and aft of vertical.
//greg//
/ Top link attachment for maximum raised height? #7
The lower of the top holes on the landpride rake and back blade is for use with a 3pt quick hitch adapter. This information appears in the manual for their quick hitch adapter not the implement's manuals. Sorry but this info does not help answer your original question.
Vernon
/ Top link attachment for maximum raised height? #8
//greg//
GIJOE is right. That combination - low on tractor&high on implement kicks the back of the implement high more quicly as it is lifted.
Larry
/ Top link attachment for maximum raised height? #9
Another thing to check is the LENGTH of the top link vs. the length of the bottom lift arms. The top link needs to be the same or shorter than the bottom lift arms. Otherwise, geometry will dictate that the top link will force the top of the implement BACK and will want to drive the rear of the implement into the ground.
I ran into this problem when they delivered my JD 4010 with LX4 brush hog. They had the bottom lift arm pivots on the LX4 in the TOP holes. The LX4 would lift about 1" above normal mowing height.
I read the LX4 manual and relocated the pivots to the BOTTOM holes. This kicked the top link attachment back towards the tractor when the mowing height was adjusted again. THEN, the LX4 would lift its rear wheel off the ground.
It's all geometry.
/ Top link attachment for maximum raised height? #10
Larry
Sorry Larry, you're both wrong. Even though it's a silly argument - because lift is performed by the lower arms anyway - you can get the top of the implement A-frame farther from the ground one when the tractor end of the adjustible toplink is in the top hole and the implement end is in the bottom hole. The angle of the implement itself is arbitrary, because the length of the toplink is variable.
Think about it. Your way - tractor bottom and implement top - can still be improved upon by at least another inch. You gain an inch from the ground going from the tractor bottom hole to the tractor top hole. On the implement end you can lift the A-frame an inch higher by using the lower hole instead of the upper.
But this is arguing just for the sake of arguing. Back to the original poster's question, achieving max height in the carry position is less important than getting the toplink as close to parallel (with the lower lift arms) as you can when the implement is in the working position. Don't go for height - go for parallel (or horizontal as I wrote above).
//greg//
/ Top link attachment for maximum raised height? #11
//greg//
No. It happens automatically as you raise it. The back of the implement pivots high as you raise to max height. This happens because the toplink reaches an extreme angle wrt to the lift direction. The top implement point is pulled toward the tractor and is restricted in rising even as the lift arms force it upward. This causes the back of the implement to kick up.
/ Top link attachment for maximum raised height? #12
I'm betting you're just basing this argument upon watching what your specific configuration does. You're not looking at it as a matter of geometry. As I suggested before, your argument is directly related to the length of the toplink - not to what hole it might be pinned to.
But can you at least agree that hole selection should be based upon gettin' the toplink parallel with the lower lift arms in the work position - and not how high anything goes in the carry position?
//greg//
/ Top link attachment for maximum raised height? #13
Greg, From the standpoint that the top link could become angled straight up during lift and thereby be holding the implement down, you are right. Ive never seen it happen, but if it did, I would lengthen the link such that the lift arms did not stall. I cant imagine this being an optimum arrangement for use, but it will produce the highest lift since the lift arms will lift the implement front as high as ever and the back will be kicked up significantly.
I agree about it being best to keep 3pt arms parallel. This lets you lift the implement straight up without pivoting it wrt the tractor. This allows you to maintain full hydraulic lift capacity regardless of how far back from the lift eyes the weight is concentrated. The apparent leverage is thus borne by the tractor instead of the hydraulic arms.
When using a boom pole unconventional toplink configurations can be a real benefit in getting the type of lift characteristic you need.
Larry
New/Unused Quick Attach Open Back Mounting Plate (A65583)
New/Unused Quick...
2019 FORD F-250 SUPER DUTY (A65643)
2019 FORD F-250...
2012 Freightliner M2106 Bucket Truck, Terex Hi-Ranger HR52M, 52FT Platform Height (A63689)
2012 Freightliner...
John Deere 530 MoCo (A66408)
John Deere 530...
2017 Ford F-150 4x4 Pickup Truck (A64556)
2017 Ford F-150...
2009 Ford Escape SUV (A64557)
2009 Ford Escape...
