Toothed Bucket Build
/ Toothed Bucket Build #1
David Devuono
Platinum Member
Brampton, On\lot Powassan, ON Canada
Kubota B4200\MF 135\Kubota B3200
Since I have a 54 inch quick attach bucket on my B3200, I have been thinking about building a stronger toothed bucket. Last night I penned a drawing and this morning I dropped $300 bucks at the Steel shop. I have 3 hours into it and hope to be ready for primer tomorrow if I don't run out of welding wire.
/ Toothed Bucket Build #3
Looks good! Are the teeth high carbon or mild steel.
/ Toothed Bucket Build #4
It looks nice. Was it cut with a plasma cutter?
The slightly narrower bucket should help it dig better.
You might consider longer teeth, or some reinforcements along the bottom. At least I thought the teeth in our old international bucket extended the length of the bucket (bolt on?), although I'm seeing many that appear to be shorter.
Perhaps a strip of sharpened half inch x 3" or 4" steel along the bottom. Grader Blade Edge?
If you're using mild steel, you could build high strength points on the teeth by extending along the bottom beyond your grader blade edge.
/ Toothed Bucket Build #5
Are you sure you dont want the bucket teeth to ride below the bucket edge a little ? You could also weld a piece of bucket edge under the teeth, to make them cut at the right hight, and as well make them sharper for easier penetration.. :)
/ Toothed Bucket Build #6
I have welded mild steel to the bucket on dads old KX-41 and found that they wore pretty quick. On my tractor I bought 7 teeth that bolt on. The teeth are the same ones I use on the backhoe.
/ Toothed Bucket Build #7
Where did you source your teeth? I think I need some.
/ Toothed Bucket Build #8
I bought them from the Mahindra Dealer here. They came from the same supplier the manufacture uses. Not sure if this helps.
Actually the first picture was just with the teeth resting on top for a visual. The teeth are mild steel 1x1 solid bar. I have been looking at some interesting buckets on Youtube and like the idea of a bit longer teeth. Mine are 2.5 inches beyond the bucket. The bottom edge of the bucket is just over 1/2 inch thick. I have left to add metal to the top of the bucket and a few odd pieces to stiffen up the bucket and then about 40 feet of welding.
Basically I was not sure of the exact sizes I needed so I bought a 4'x8' sheet of 3/16th and had the steel shop cut all the pieces on the 4 ft side. IE 3 pieces at 12" x 4' of which I used two. 2 pieces at 6" x 4' of which I ended up using one, 2 pieces at 3"x 4ft which I used most of. I also have left one Piece of 10" x 4ft and 14" x 4ft as I was not sure until I mocked it up what sizes I would need. One piece of 3/8 thick x 4.5"x4ft, and 4 ft of 1"x1" solid bar. I have had good luck with using mild steel teeth on my backhoe (1.25 square) so will try it again here. Not like I use it more then a couple dozen hours a year. The remainer of the 4'x8' sheet was sheared into 1.5 inch wide pieces for some track plates for another project.
Tooth material depends a lot on the soil type found on your property. I can dig almost anywhere on my 195 acres and can only wish to find something other then a layer of topsoil, then fine sand (drys like beach sand) and clay. Nice thing about mild steel teeth are, that if they don't break, they will never wear out because I can just build them back up with weld.
Bucket finished and tested. Drove to several spots before I found one were the ground was not frozen.
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
Miller Millermatic 212 Auto-Set MIG welder (A63689)
Miller Millermatic...
2022 TEXAS PRIDE DUMP TRAILER (A65643)
2022 TEXAS PRIDE...
JOHN DEERE 300P EXCAVATOR (A65053)
JOHN DEERE 300P...
2007 HEIL TRAILER (A65643)
2007 HEIL TRAILER...
