Toothbar Tutorial (my Version)
/ Toothbar Tutorial (my Version) #1
Inspector507
Super Member
Central Ohio
Here are some photos as I put my toothbar on last night. The 54" toothbar weighs about 60-70 lbs I'd say.
I used yellow duct tape under the ears so I could see where to drill the holes. Hard to see a black Sharpie mark on a black bucket.
Holes are marked on both sides
Used a 1/4" hole to start. DeWalt pilot tip bits are great.
Next went to a 1/2" hole on both sides
Thought you'd like to see the late 50's, early 60's era 1/2" Craftsman Drill I used. It only runs at 600 RPM, but as you can see has enough torque to snap the rear handle off of it. I did that years ago. While drilling these holes, I think the RPM may have dropped to 595..... /forums/images/graemlins/grin.gif
Couldn't locate the step drill bit I wanted to use to make the hole 3/4". Used this Unibit instead. Drilled both sides of the metal because this bit is 7/8" total and I didn't want to make it that large.
Test fit the bolts......yep they fit real good /forums/images/graemlins/grin.gif
Here I am all finished with the install.
Total time, 50 minutes, including going out back to bring the tractor around, taking pics and cleaning up
/ Toothbar Tutorial (my Version) #11
Thanks a lot for posting these! I found them very helpful, and thanks to you I will order a toothbar for my bucket.
/ Toothbar Tutorial (my Version) #12
That sure does look like the same toothbar I had on my B2710. /forums/images/graemlins/wink.gif Sure will make that FEL dig better.
Bird,
Thats a toothbar from WR Long.
Ken,
You're welcome. I see a few posts now and then about people wondering how to install one. I can tell some of them fret about how to drill a 3/4" hole in 1/4" steel.........it isn't that hard to do at all.
/ Toothbar Tutorial (my Version) #15
Nice Job,
You did a better job then I did. Mine ended up with about a 1/4th inch space between it and the bucket. Works ok just fills with small rocks and stuff in the gap.
-Terry
/ Toothbar Tutorial (my Version) #16
Nice job Inspector. Your going to love that toothbar. /forums/images/graemlins/grin.gif
/ Toothbar Tutorial (my Version) #17
I have the same toothbar, only the 48" version. I love it. It really helps to dig.
2 suggestions: use anti-sieze on the bolts if you intend on taking the toothbar off in the winter
and I put the nuts on the outside because I also have a few exposed threads. I think the most wear would occur inside the bucket, not outside. This is again to aid in taking it off in the winter.
Dave R.
/ Toothbar Tutorial (my Version) #18
Inspector,
I'm in the midst of installing a toothbar on my JD FEL. I did exactly as you did through drilling the 1/2" holes. I've worn out two unibits trying to get from 1/2 to 3/4. I thought about buying a 3/4 bit or two, but I don't have a drill with a 1/2" chuck. Is there a secret to getting a unibit to last long enough to drill my holes? Or do you have any other thoughts on how I might finish this little project. I'm a little frustrated as I can't play with my new toothbar.
Thanks.
Doug,
You need to make sure you're using a step drill without the very small steps to it. The one I used has maybe 6 steps and not 13. The 13 step bits are for thinner material and will burn up in a hurry with ¼" material. GO SLOW use a lubricant
/ Toothbar Tutorial (my Version) #20
Just curious as to why the holes were placed in the front of the slot as opposed to the rear. I put my tooth bar on a couple of weeks ago and I put the holes to the rear of the slot. I have used the heck out of it on stumps and have not noticed any problems. I just want to be sure I did it correctly
GENIE S-60 MANLIFT (A60736)
GENIE S-60 MANLIFT...
DITCH WITCH JT60 ALL TERRAIN HORIZONTAL BORING MACHINE (A60736)
DITCH WITCH JT60...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Bell 1600 Gallon Nurse Trailer (A61307)
Bell 1600 Gallon...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
