Toothbar idea
/ Toothbar idea #1
OldJD
Minnesota
John Deere 720
I've got a bucket of old railroad spikes in my shop. Has anybody used RR spikes to make a toothbar? My Gehl skid steer has a 54" bucket and I plan to get some 1/2" flat stock for a structural member and weld the spikes on at downward angle. From other postings, it appears that a bolt or two in the center, in addition to bolts at each end, will reduce the likelihood of twisting the bar.
Each RR spike is about 7 inches long and about 3/4" square with two edges beveled to a point.
Will the RR spikes be stout enough? My loader has a specified lifting capacity of 800 pounds.
Thanks in advance for any comments.
/ Toothbar idea #2
Heck...even if the spikes fail to hold up...not much cost to try.
I'd do it. I'll wait patiently for the results as I have a few kicking around myself.
/ Toothbar idea #3
Many of the toothbars are made such that a "v" shape goes over the cutting edge for extra stability. One bolt at each end is all that is needed. I'd put your spikes on an angle that goes over the cutting edge, then you don't need to cut any more bolt holes, but I think they would be tough enough to do some work. John
/ Toothbar idea #4
I don't know how you would stabilize them over the edge of the bucket so they could do the most work. But since you have them I think it's a good idea to give it a shot. I hope they work out for your needs. If you get it welded up pease post a picture or two.
/ Toothbar idea #5
SIR,
have you looked at a tooth bar? it is
made so the edge of the bucket takes
the force of digging. they do this by
cutting a notch in the back of the bar.
this fits onto the edge of the bucket.
on mine, the teeth are held by welding
them onto a 1/2in by 3in steel strap.
these are secured only on the ends, by
a 3/4in bolt.
accordionman
wlbrown
/ Toothbar idea #6
I can't remember who, but a few months ago someone posted pictures of his homemade toolbar in which he welded two plates together to capture the edge of the bucket. He then welded the non-V notched teeth to that. It looked good in the pictures and he said it was holding up well in use. I think that method would probably work with the R/R spikes.
Terry
/ Toothbar idea #8
Don't know about tooth bar but I made a rake using railroad spikes. I got a large screen, and drove the spikes through the screeen, I used large washers on each side of the screen then tack welded the washers to the spikes. Its about 3 foot deep and 7 foot wide. It makes one great rake for large pastures.
/ Toothbar idea #9
Last year, I made a toothbar from a steel bar (3/8" x 3" ) and some forged combine teeth- it's worked fine, even digging in rocky gravel that's too hard to shovel by hand, but I have it on a modestly sized CUT with only 650 lbs of lift capacity... here's a picture of it, once again:
/ Toothbar idea #10
and from below:
/ Toothbar idea
Here is an update on my toothbar plans.
Before welding up RR spikes on a section of cutting edge, I am considering cannibalizing an old sickle bar mower that I dragged out of the woods today. The mower has a MM plate and a 7’ bar. My plan is to cut off a 54” section and bolt it directly to the bottom surface of the existing cutting edge on my Gehl skid loader. I am considering cutting internal threads on the sickle bar and running hex head bolts down from above.
Your comments are appreciated.
I will plan to post a picture when done.
/ Toothbar idea #12
As long as the mower is 'beyond salvation'.. I'd say that's a good idea.. blade guards.
You could also use plow bolts.. or carriage bolts.. plow bolts would / could be flush with some drilling and or filing.
I've sucsesfully installed cariage bolts by drilling a hole that will almost accomodate the square sub head, and then filing it out to fit..
Soundguy
/ Toothbar idea #13
OldJD,
Here's a photo of the toothbar I made for my 72" bucket. I used a piece of 1/2" x 4" cutting edge and some 1" x 1" tempered bar stock with one end cut on 45's for the shanks. The teeth are bolt on skid loader teeth. Total cost of the project was $120, with the biggest expense being the 72" cutting edge @$60 . This bar wasn't used much yet but I made another one exactly like it for my B2150 when I had it and it worked great. If you take notice, this bar is mounted on top of my present bucket cutting edge. This makes the bottom of the teeth approx. 3/4" off the ground surface. I made it this way because I do alot of work on macadam roadways and this way I can put my bucket at a level position and scrape ground off the road with out having the teeth dig in leaving grooves on the roadway. The 2 center bolts on the cutting edge are plow share bolts and are countersunk into the bottom of the bucket cutting edge for a flush fit.
Bill
Generac Speedwash Pressure Washer (A65640)
Generac Speedwash...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A65054)
(INOP)1989 NISSAN...
2011 Ram 2500 Longhorn Laramie 5.7 HEM (A62679)
2011 Ram 2500...
2016 BOBCAT E35I MINI EXCAVATOR (A62613)
2016 BOBCAT E35I...
New/Unused ATS 13000 Pound Electric Winch (A65583)
New/Unused ATS...
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
