Toothbar and Palletworks
/ Toothbar and Palletworks #1
TGF
Blair, NE
3038E
After searching the forums for about an hour I decided a tooth bar is just as good as a tooth bucket for what I am going to be doing and that Markham Welding is a good place to get one.
Barring any additional toothbar info, I was wanting to get peoples thoughts on these.
Tractor Forks, Bucket Forks, Loader Forks
They seem like they wouldn't work very well and would stress the heck out of your bucket and FEL. They are 1/3 the price of a manufacturer set of forks.
/ Toothbar and Palletworks #2
I guess they'd be ok for light duty (maybe 500 lbs, maximum). I sure wouldn't use them for a pallet weight near the loader's capability.
That was my thoughts as well.
/ Toothbar and Palletworks #5
Just thought of something. If you have a tooth bar on your bucket I doubt these clamp on style pallet forks would work. You'd probably have to take the tooth bar off first.
/ Toothbar and Palletworks #6
I bet they won't safely lift much more weight than I could wrestle into the bucket by itself. No I am not that strong, but I have a lever dolly and am pretty good at getting things into the bucket.
If I was going to be using them a lot, I would get purpose-made forks because of the much better visibility.
If I was going to only use them a little, I would spend much less money on a good lever dolly (look in the Northern Tool Catalog) and keep some wooden blocks on hand.
I think you guys have confirmed my suspicions, I will just save some bucks and get a real pallet fork attachment for the FEL.
/ Toothbar and Palletworks #8
I've found used pallet forks with the SSQA for $500 to $700. They are definatley built to handle more weight than a FEL can handle.
SSQA? sorry not familar with all the acronyms yet? Is there a forklift style FEL attachment where I could hook up my AUX hydrolics to make the elevator work?
/ Toothbar and Palletworks #10
I have some chain on forks and they seem plenty strong. They go on with the tooth bar in place. You just fit them between the teeth.
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
Cushman Hauler 1200X Golf Cart (A57148)
Cushman Hauler...
2005 Wacker Neuson PDT3A Portable Diaphragm Pump (A59228)
2005 Wacker Neuson...
CH and E 2909T 6in Towable Trash Pump (A59228)
CH and E 2909T 6in...
2016 Ford Taurus AWD Sedan (A59231)
2016 Ford Taurus...
