Toothbar and Palletworks
/ Toothbar and Palletworks #1
TGF
Gold Member
Blair, NE
3038E
After searching the forums for about an hour I decided a tooth bar is just as good as a tooth bucket for what I am going to be doing and that Markham Welding is a good place to get one.
Barring any additional toothbar info, I was wanting to get peoples thoughts on these.
Tractor Forks, Bucket Forks, Loader Forks
They seem like they wouldn't work very well and would stress the heck out of your bucket and FEL. They are 1/3 the price of a manufacturer set of forks.
/ Toothbar and Palletworks #2
I guess they'd be ok for light duty (maybe 500 lbs, maximum). I sure wouldn't use them for a pallet weight near the loader's capability.
That was my thoughts as well.
/ Toothbar and Palletworks #5
Just thought of something. If you have a tooth bar on your bucket I doubt these clamp on style pallet forks would work. You'd probably have to take the tooth bar off first.
/ Toothbar and Palletworks #6
I bet they won't safely lift much more weight than I could wrestle into the bucket by itself. No I am not that strong, but I have a lever dolly and am pretty good at getting things into the bucket.
If I was going to be using them a lot, I would get purpose-made forks because of the much better visibility.
If I was going to only use them a little, I would spend much less money on a good lever dolly (look in the Northern Tool Catalog) and keep some wooden blocks on hand.
I think you guys have confirmed my suspicions, I will just save some bucks and get a real pallet fork attachment for the FEL.
/ Toothbar and Palletworks #8
I've found used pallet forks with the SSQA for $500 to $700. They are definatley built to handle more weight than a FEL can handle.
SSQA? sorry not familar with all the acronyms yet? Is there a forklift style FEL attachment where I could hook up my AUX hydrolics to make the elevator work?
/ Toothbar and Palletworks #10
I have some chain on forks and they seem plenty strong. They go on with the tooth bar in place. You just fit them between the teeth.
2012 International 4300 Reefer Truck (A61307)
2012 International...
Freightliner Fuel Truck (A61307)
Freightliner Fuel...
2008 DRAGON PNEUMATIC TRAILER (A58214)
2008 DRAGON...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
2020 FREIGHTLINER CASCADIA MIDROOF SLEEPER (A60736)
2020 FREIGHTLINER...
