Tooth bar
/ Tooth bar #1
gray
Upper Peninsula of Michigan, on the shore of Super
Kubota L48 tlb
Well, I did it. After reading so many posts on how much people think of tooth bars, I had to get one.
The snow is gone now and I found time today to put the thing on. It cost me 325 for the 72 inch with 8 teeth. I put it on in about 20 min. using a torch to cut the two holes. I went out back of the shop and ripped 5 small trees out , each about 2 to 3 inches in diameter with one angled bucket plung each. It is sandy soil and an L48 Kubota but this would not have happened before the tooth bar. Yes, it does improve the usefulness of my loader, now I have to get used to how to use it and when to use it. It will make root clearing much easier than ever.
Thnaks to all who shared their knowlege on TBN.
Gray.
/ Tooth bar #2
Hey Gray, Your tractor no longer has that toothless grin. You're gonna love it. John
/ Tooth bar #3
Gray: ...... I, too have read about all the advantages of a toothbar & like you have sprung
to add to my FEL. /forums/images/graemlins/cool.gif
The installation was easy ( using the techniques that were reported here ) 3/4" holesaw worked great!
/forums/images/graemlins/smile.gif My install was on a LA402 Kubota FEL @ $273
( 6 tooth from NH dealer) see photo.
It still is wet and soggy at my place, so it will be awhile before I can test. /forums/images/graemlins/laugh.gif ....RayBee
/ Tooth bar #4
I got one this spring also and it is unbelievable what a difference it makes. I like it for brush even better than dirt and I hadn't been counting on that. It's even worth the extremely high $417 I paid for it.
/ Tooth bar #5
I'm also including a closeup of the bolt-on bracket.
Notice the double slot ( I guess for flexibility of fitting many buckets ) /forums/images/graemlins/smile.gif
I hadn't seen this before on previous posts.
New Holland buys these from FFC to fit their buckets.
You can check the specs. here -- www.sweepster.com/buckets/tbar_sd_specs.htm /forums/images/graemlins/cool.gif ......RayBee
/ Tooth bar #6
Ray,
You may want to consider adding a few nuts to cover the threads on the bolts. All it takes is one stone to hit the threads and you will have a lot of fun taking the bar off.
/forums/images/graemlins/confused.gif
/ Tooth bar #7
I put my bolts in from the inside out and cut the extra off so that I didn't end up catching my leg on them easily either.
/ Tooth bar #8
I wrap black tape around the exposed threads and cap the end with plastic caps. It seems to work.
/ Tooth bar #9
Gray, whos tooth bar did you buy? Twenty min. install sounds good to me .Also if i might inquire as to price. The more I read posts about tooth bars the more I feel I'm going to need one. Thanks in advance for any info, also enjoy your new teeth. /forums/images/graemlins/smile.gif John
/ Tooth bar #10
Good Tips -Guys /forums/images/graemlins/cool.gif ....Raybee
/ Tooth bar #11
</font><font color="blue" class="small">( I'm also including a closeup of the bolt-on bracket. Notice the double slot ( I guess for flexibility of fitting many buckets ) )</font> RayBee, on my Woods Toothbar, that mount is a slot, open all the way instead of having double slot. Guess it would work the same way, but give more options. I cut the hole and put the bolt in closest to the font of the slot (cutting edge side). I wasn't sure if that was a good idea, but it's holding well. Wish I had had a 3/4" hole saw, I had a 1/2" drill bit and did the rest with my dremel tool with a grinding wheel. Actually worked quite well. John
GREAT PLAINS TURBO-MAX 1200 - 12' VERTICAL TILLAGE (A64277)
GREAT PLAINS...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
1999 AMERICAN EAGLE CLASS A MOTORHOME (A65643)
1999 AMERICAN...
16.5' Telescoping Ladder (A66408)
16.5' Telescoping...
2011 International 4300 Versalift Bucket Truck (A64194)
2011 International...
84in. Light Duty Fork Extensions (A65640)
84in. Light Duty...
