Toolcat Snow Removal
/ Toolcat Snow Removal #12
I use the "doggy offset" or "crab" steering feature when removing snow next to a ditch or rounding a tight corner. First place the rear wheels out from the ditch just a bit and then switch to front steer only. This will keep the Toolcat's rear end away from the ditch and keep the Toolcat from sliding into the ditch if you get to close. Offset or crab steering is also great for pulling out of a ditch if you do slide into one. When rounding a tight corner and I want to cut close to the curb, I use the same method to keep the blower or plow right on the inside curve of the turn and the rear wheels away from the snow bank. Works wonders when you get the hang of it.
1993 CHEVROLET Corvette (A59231)
1993 CHEVROLET...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
John Deere 344L Articulated Wheel Loader (A60352)
John Deere 344L...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
2022 FORD F-150 XLT CREW CAB TRUCK (A59823)
2022 FORD F-150...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
