Toolcat 5600 tracking issues
/ Toolcat 5600 tracking issues #1
rwpeyton
Round Lake, MN
Bobcat 5600 Toolcat
I have a 5600 Toolcat and I am having issues with the rear wheels not staying tracking straight, even when it is locked into front wheel steering. I continually have to switch to all wheel steering and turn my back wheels until the wheel straight light comes on then I can switch back to front wheel steering for a very short while then I have to repeat the process. In short the rear end drifts. I contacted the service department for our local Bobcat dealer and they told me the didn't know where to begin and it would cost me $10,000.00 or more to get the answer. Help!!!!
/ Toolcat 5600 tracking issues #2
I certainly don't know toolcats, but it must be either a leaky valve or a leaking cylinder (side to side, not necessarily dripping on the ground).
All I can think is to disconnect the lines and put caps on the cylinder. Drive around. Does it drift?
Probably should cap (or connect?) the lines that were disconnected from the cylinder, too. :)
If so, cylinder problem. If not, some valving/control issue.
/ Toolcat 5600 tracking issues #3
Any chance you got air in lines. I had a loader issue once that was secondary to air in lines. It resolved once air was removed. BTW , bobcat wanted around $1300 for a new joystick.
/ Toolcat 5600 tracking issues #5
Our 12 ton Dynalift telehandler used to do the same thing. You had to keep fixing the orientation of the back wheels. I guess it was just worn hydraulic cylinders or valves. I just got used to it.
/ Toolcat 5600 tracking issues #6
Check rear alignment of tie rods. Misalignment can cause your issue.:thumbsup:
/ Toolcat 5600 tracking issues #7
Or simply your tie rod ends. Not sure why but when Toolcat tie rods get stressed they break allowing the rod down shaft to swivel / move in the rod end. This gives you about 1-2" of play in a wheel.
Has anyone else noticed this failure mode?
/ Toolcat 5600 tracking issues #8
It can throw you off because you still have steering but you can drift
/ Toolcat 5600 tracking issues #9
I had a tie rod fail some years back, and while its been a while I do believe the main symptom was that it would not track straight while roading.
/ Toolcat 5600 tracking issues #10
You just jogged my memory, all 4 mounting bolts loosened and fell out of the rear steering cylinder. :eek:
/ Toolcat 5600 tracking issues #11
Does it always drift in the same direction, or does the direction of the drift vary?
My thought is that you should try checking your steering selector valves on the back of the machine underneath the dump bed. To me it sounds like one of your valves may be stuck open allowing Hydraulic pressure to be applied to one side of the back steering cylinder.
The steering selector valve block is mounted just above and foreward of the back steering cylinder and is best accessed from above the machine. It has three valves(middle one is a relief valve) and a solanoid for each valve. When in 2 wheel steering mode, fluid flows to this valve but then is diverted back to tank. Once you switch to 4 wheel steering mode, it actuates these three valves, and fluid can flow to back cylinder. Without any testing, my thought is that one of these valves is stuck open, therefore fluid pressure is always being applied to one side of the rear cylinder even when you are only in 2 wheel steer mode.
Feel free to contact me if you wish to discuss further.
Sam
2025 Miscellaneous Mini Excavator Attachments (A64553)
2025 Miscellaneous...
2025 MACK GRANITE GR64F DUMP TRUCK (A63276)
2025 MACK GRANITE...
(INOP) 2022 MACK MD6 WATER TRUCK (A64280)
(INOP) 2022 MACK...
Man Basket Boom Lift Attachment (A64553)
Man Basket Boom...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2012 Ford E-450 Sewer Viewer Van (A64556)
2012 Ford E-450...
