laurencen
Veteran Member
- Joined
- Feb 19, 2007
- Messages
- 1,211
- Location
- saskatchewan Canada
- Tractor
- Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
my recently purchased toolcat 2003 vintage has next to no heat, using the manual I removed the drivers seat, found the valve, checked the 12 volts but when turning the pot on the dash nothing on the other two wires to the valve, too cold to remove the dash pot.
getting back to the valve, if I remove the outlet hose water is flowing good so the valve is open, coolant is defiantly hot and gauge is lower side of the green on the dash display, turn fan on and the air flow is decent, problem its cold, some sign of heat just not warm.
I removed the covers on the lower console passenger side, one is inlet side and allows you to see the AC core, dirty as there is no air filter, the other cover gets access to the heater core, the lines at the core are hot, the heater core also gets hot, turn fan on and cold at the vents, I tried leaving the fan off for a short time and on with the fan, nothing for warmth.
I think the core may be blocked and only picking the heat from the edges of the heater core due to running without filter, any other thoughts as to what it can be, there does not seem to be another hole the fan can pull cold air in bypassing the heater core I can see.
when the snow stops tomorrow I will try blowing compressed air thro the both cores from the heater side and see what exits, if lots of crap comes out it may be the issue but would like any other idea that is preventing heat
the AC is not the cause as Im told the belt is off the compressor
thanks in advance for any ideas
