Toolbox on 2305
/ Toolbox on 2305 #1
2305JD
Southwest Ontario, Canada
JD 2520
Has anyone figured out a toolbox solution for the 2305.
I checked out local hardware stores today and all I found were big metal boxes (all red too...) that would not look good on the 2305.
thanks...
/ Toolbox on 2305 #4
Here is what I did on my former 2210 and it worked very nice. The tool box is 12" x 6" x 5" deep and I used the two bolts that held the top link up. In this set up, you have to remove the top link when not in use, but other than that, the set up worked very nice and allowed quick/easy access to pins, etc., when working at the rear.
/ Toolbox on 2305 #5
That's cool. /forums/images/graemlins/cool.gif
Do you think if you used nylon or rubber washers/grommets you could have put the box over the mount for the centerlink Clip.
I've got to work on making one of those. I've looked at the 'seat bag' type covers but they don't hold as much as a toolbox and aren't as nice looking.
/ Toolbox on 2305 #6
Orlo,
Actually, I used a 3/4" thick strip of rubber (almost the size of the underside of the box) and sandwitched that between the box and two bolts (just drilled through the bottom of the box and ran the bolts through the inside down), so this allows the box to flex a bit if needed. The little box worked great and I'm going to replicate that again on my new 2210.
/ Toolbox on 2305 #7
Here's a pic of my toolbelt that I keep on the top of the FEL tower. It has channel locks, tin snip scissors that also serve as pruners for vines/small branches in the way, multi-screwdriver, knife. I have an old floppy carrying case that I've attached to the top part of the grill behind the FEL that I keep a big hammer and ice pick in.
Used to carry a tool box in my Gravely cart all over the place and found I didn't need all that stuff. Mainly what I need fits in the tool belt and that floppy case.
Ralph
/ Toolbox on 2305 #8
Just like the one in the pic on the next post
/ Toolbox on 2305 #9
nice idea jd2210. I was wondering where I might place a small box, yours looks nice.
/ Toolbox on 2305 #10
Very nice install indead. I like the use of suitcase weights on the BB too. I'll have to try that
UNUSED SDLANCH ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
5000 GALLON WATER TANK W/RELEASE VALVE (A64280)
5000 GALLON WATER...
Woods 20A600 (A64119)
2012 Mercedes-Benz 2500 Sprinter Van (A61573)
2012 Mercedes-Benz...
2015 NEW HOLLAND BOOMER 41 TRACTOR (A64280)
2015 NEW HOLLAND...
