Toolbox for M7040 cab
/ Toolbox for M7040 cab #1
CCOUGHRAN1
I purchased a M7040 cab earlier this year, and it came with a cheesy little plastic toolbox between the front left tire and the steps. I set the tires about 4" wider, and now the tires hit the toolbox.
Any suggestions for an alternative mounting location for the factory toolbox or a larger aftermarket toolbox?
/ Toolbox for M7040 cab #2
I just run without a toolbox now,usually have my pickup close. I bought pens for every piece of equipment and just leave them with it when im done using,small piece of baling wirer attached to pen so they dont get lost... You probaly need somewhere to keep shear pins and wrench maybe weld/bolt small metal toolbox on batwing...
/ Toolbox for M7040 cab #3
This is what I did to my M8540, works great!
E/S
/ Toolbox for M7040 cab #4
I have a m6040 and added a metal tool box where the SMV sign is on the left rear of cab and then moved the sign to the right.
/ Toolbox for M7040 cab #5
I guess I'm different. I had a M4900 with "no toolbox" so when I purchased my M7040 that had a toolbox I was happy.happy. I'm curious how does moving tires out 4" get tire closer to toolbox?? Does your tractor have a frt end loader? Mine does and toolbox is bolted to it. I don't think it would do that on my M7040 but I'll look this AM.
Thanks for the feedback/ ideas. I guess I spoiled myself having a 24" x8" x10" toolbox on my gl3940. I kept scrubs handwipes, tools pins rags etc.
I keep a soft toolbag in the cab of the 7040, but long for a decent toolbox.
Tx Jim,
The interference occurs on a hard left turn, the outside lugs on the tire dented the corner of the plastic toolbox. I dont have the fronts set at max width either. I ended up having to remove my toolbox and bracket.
/ Toolbox for M7040 cab #7
Tx Jim is this where ours was mounted and tires hit. That where yours is?new 7040.JPG
/ Toolbox for M7040 cab #8
My TB is mounted at the same place. I haven't had the tractor very long but I'll check it out when the weather warms back up.
/ Toolbox for M7040 cab #9
My left frt tractor get's nowhere close to touching the toolbox in a left hand turn. What size frt tires does your tractor have? Mine has 9.5X24's.
/ Toolbox for M7040 cab #10
This is what I did. Since I hardly ever used the right side steps I removed them and used the mounting point to attach my tool box bracket. It is as high as I could get it and still open the cab door. NOT a huge box but plenty big to keep a 4 pound shop hammer, 15" crescent wrench, pins etc
/ Toolbox for M7040 cab #11
They dont come close at factory settings but widen your front stance by turning your rims around and see...
/ Toolbox for M7040 cab #12
I'm having a difficult time seeing how widening the frt tire spacing is going to get tire closer to the toolbox. Just how wide are your tractors frt tires?? I don't go to Casino's but I've been known to make a wager.
I didn't think clearance would be an issue when I moved my tires either.... until they were moved, and it became an issue!
I don't have my tractor handy to take a pic of the wheel setup, I'll try to get a pic tonight when I go feed cows.
/ Toolbox for M7040 cab #14
Would a wider tire come closer to toolbox? Same diff. moving the tire out 6inches....
/ Toolbox for M7040 cab #15
I was thinking larger diameter not width.
Here is the pic of my tire/wheel setup. I flipped the dish, then swapped sides on the rims. Seems like I went from a 59" center to center, to a 66 or 68" center to center, ~4" on each side..
I didn't realize the pic was upside down until I uploaded it....
2014 Ford F-150 4x4 Ext Cab Pickup Truck (A64194)
2014 Ford F-150...
2025 JOHN DEERE 333P SKID STEER (A65053)
2025 JOHN DEERE...
TRUCK RAMPS (A64556)
2005 Terex TX55-19 4x4 5,000lb Rough Terrain Telehandler (A64553)
2005 Terex TX55-19...
Swict 72in Bucket Skid Steer Attachment (A64553)
Swict 72in Bucket...
Winchester Sign (A64557)
Winchester Sign...
