tool box mount
/ tool box mount #21
That said I have dumped old clean motor oil in my tractor to get rid of it, these motors will run on lots of stuff. Oil was diluted in almost 5 gallons of fuel not like I ran straight oil. It was a quart.
I've done that a couple of times, poured a small remainder of a container into the fuel. Not a whole quart though. One lesson I earned: a small amount of gear oil will burn fine but with a strong unmistakable smell of severely overheated transmission. Until the entire 5 gallon fuel tank is ready to refill. Not recommended. :)
/ tool box mount #22
Just sat back down from getting my eyes checked and glasses replaced. While I was in waiting area this came to mind. I thought real hard about picking up the TWC3. If I didn't have to go out of my way to get it I would have. When Walmart gives you the okay It must be useful. I'm with you Jtullis13 after thoroughly checking on it and thinking. It would be wise to use the TWC3 . When Wally world tells you it's useful you can pretty much take it to the bank! I keep thinking "Lawsuit" for sure if not... Just saying..........
On my Motor oil it gets changed every Yr. When I'm Sharpening blades and mower maintenance I change my Oil Regardless of Hrs.. I use the Super Tech 50 weight and always buy a extra Quart to keep it topped off. I use more in my push mower than the Tractor. Even with both I never use all of it. Honestly, I end up using most of it in my chainsaw oiler.. Those days are gone in which I've never use it long enough to run it out of bar oil..............
/ tool box mount #23
Heck I use a few gallons of bar oil a year. If you go to walmart you shouldn't have to go out of your way to get marine two stroke oil, which is tcw3 oil? Just buy you a qt of super tech marine oil. Or if you have some around put it in. I put it in every 5 gallon jug I buy. I I miss a tank I don't worry. I add what I need and if I think about it when I get some I just dose the tractor tank. I don't are if some is already mixed, as when I added pure diesel it diluted it, yea it will still be richer than needed but again I don't worry much about that.
/ tool box mount #24
Marine oil isn't easy to come by around me. Which I new that and Walmart is about the only place that will stock it. I figured I'd pic. it up there. I ran Quick Silver in which I kept plenty back then. Esp. after building the 175 block. With the price of fuel and 2/cycle. I could afford to. Plus I had $ in that Eng.. I ran 3/2 Barrel Carbs. that was jetted and todays Eng's most all are fuel Inj. and are much more fuel efficient. I would go through a half gallon of 2 cycle @ 32:1 filling the tanks.
Which I mixed and don't know for sure but I think the Oil Inj. took the first motor out we repairerd. I thought there would be a special blend. Also had to chuckle wishing my saw had an Elec. starter L.handed still isn't easy. That was the first thing to I lost most of is my R.Arm and Hand plus other injury's from it. And that should have killed me and the reason I sold the Ranger...Getting old...........
/ tool box mount #25
i have a 1990 Evinrude 150GT with the triple 2 barrel carbs!! That's on my fish and ski. I know the kind of fuel that thing uses!!!
/ tool box mount #26
... building the 175 block. ... I think the Oil Inj. took the first motor out we repaired. ... I lost most of my R.Arm and Hand plus other injury's from it. And that should have killed me...
The 175 blew up and messed up your arm? I'm sorry to hear that.
/ tool box mount #27
Wow no I lost most of my mobility of my Arm and Hand. It was a freak work accident California. It's hard to type and was multitasking on top of that!! Then the Bad one happened..
Leaf season is almost over finally and only had to get the can refilled. I had to go inside so I checked the 2cyl. which they had and also had Qts. of Q-silver which did state TWC3.. After seeing the price 6.99 I'll go Walmart clemsonfor. And be happy to do so........
/ tool box mount #28
Yea you can buy a gallon for like $11 or so these days.
All marine two stroke is tcw3 now a days. Or well it should be. Even no name or private label oils would carry that certification. It's the same basically as what ever the diesel oil certification. Or regular oil that is SJ rated or whatever letter they are up to these days.
/ tool box mount #29
I just noticed there is an old similar thread with the identical question and a broader range of solutions, compared to this thread:
Where to mount a tool box
That should give the Original Poster here some good ideas on how to mount his tool box.
But please lets continue now in this thread instead of posting over there. It's too confusing to have identical threads active.
/ tool box mount #30
I actually was getting there. Someone get butt hurt? If you look at the advertisements. Well can't say for everyone so have to be careful. If you do see up at the tool boxes the Rolling Org. Red work box. Well my Brother gave me one key and all. Now it's how I want to set it up. I'm thinking because of the wheels they won't last long pulling it. Maybe go ahead and replace them and pull it. Or try and just lift the box using the 3pt arms. Turn it sideways? Angle Iron the bottom for support? I think I can do it that way and possibly still be able to use the 3pt also. I'll never be useing the Pto. shaft much but on the BH. and that would be the only thing for me. I'm thinking the PTO. shaft may even fit in the box. I need to do it. I just lost my good glasses working in the wooded acres I live on. Could have avoided that. More like finding them in Hay Stacks. So that didn't help. Idea's? I'm leaning toward make a frame and lift it. Worst case of course with wheels on it and then remove it and roll it around. OH!! Have to go!!!! Fire trucks are at the house across the Hwy. Idea's.
Thanks.
Didn't last long thank goodness. Rescue,Ladder truck and Ambulance. Wasn't there long that's for sure. Ambulance and Rescue a few times but a first with the Ladder truck also. There going to take that old ladies life alert away. Fireman and the attention is sure looking that way. 10Min Tops all 3............... Stuck in the Bathtub "again" I doubt with the ladder truck...
And I noticed It may not even be up there or the right one for that matter. Another model showed up that rolls but it's vertical.
https://images-na.ssl-images-amazon.com/images/I/81ojOQJvzgL._SX522_.jpg
2018 Nissan Versa Sedan (A59231)
2018 Nissan Versa...
2009 CHEVROLET C8500 DUMP TRUCK (A59823)
2009 CHEVROLET...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
2022 Morbark Eeger Beever 1215 Towable Brush Chipper (A59228)
2022 Morbark Eeger...
2023 Bobcat T770 (A60462)
2023 Bobcat T770...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
