Too large
/ Too large #1
B7500
Platinum Member
Tupper Lake, NY
Kubota B7500 HSD
Why, when I try and post a picture I get an error message saying it's too large? I've tried to "compress" it but when I do they look like a thumbprint picture. I'm envious at some of the other posts that looks so detailed.
-T
/ Too large #2
Resize the picture with your camera software before you load it onto the board.
/ Too large #3
Check the actual file size. Maybe even though the picture is smaller, the file size is the same size.
I think the files need to be less than 200kb.
Cheers
/ Too large #5
I use Irfanview to chnage the size and resolution of most graphics files. It is free and can be downloaded from <A target="_blank" HREF=http://www.irfanview.com>www.irfanview.com</A>. The option you are looking for is usually called Resize / Resample and you can change the size, the resolution, and the compression ratio (for .jpg files at least) for a file. The 200 K which is I think the current limit for a graphic file is plenty big for a 640 by 480 .jpg file.
/ Too large
rf33,
Thank you for the tip. I'll d/load the software and give it a try.
-Terry
