Today's stupid question: re ballast box
/ Today's stupid question: re ballast box
Re: Today\'s stupid question: re ballast box
Thanks, I like that idea John. It had struck me that it was going to be stuck wherever I dropped it off. That would solve that problem.
Graham
Graham
I like it!!! Sounds like an excuse, whoops I mean reason, for another toy. /forums/images/graemlins/grin.gif
Graham
Graham
That's an excellent idea, thanks. I've got some old piping in the garage taht would be perfect for the job.
Graham
Graham
/ Today's stupid question: re ballast box #27
Is your Ballast box a Kubota brand? If so, mine has the hitch points up about 4 inches from the bottom of the box (there's also a metal lip-type brace on the bottom of mine). If I lower the lift arm adjustment (the long brass "nut" on the right lift arm as you face the rear of the tractor), I can get the lift arms to match the ballast box perfectly (assuming I am on flat ground--concrete garage floor).
/ Today's stupid question: re ballast box #28
/ Today's stupid question: re ballast box #29
BTW... I bought the casters at TSC. I believe that the total cost of the project was under $20 and took less than an hour to build.
John
/ Today's stupid question: re ballast box #30
John
Interesting. Mine is a Kubota also (B5320 I think) and the hitch points are right at the bottom.
The more I've been thinking about it the more I like the idea from another posyer of having a wheeled dolly that I can lower it onto when not in use so I can wheel it around easily.
Graham
Graham
Thanks John.
Funny enough very recently I had made a variant of such a dolly to go down in our low crawl space so we could transport stuff we wanted to store down there around.
Mine for the tractor will have to be higher as without shifting the holes that are used by the lower link arms (which are in the right place for my rotary cutter) it'll need to be 6-9 inches high. I'll need to make sure it is stable as the weight could do a lot of damage if it tips over (probably onto my foot!).
Graham
Thanks John.
Graham
2019 Caterpillar 259D Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
(14) WOOD PALLETS (A60432)
(14) WOOD PALLETS...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
Eagle Weathervane (A55853)
Eagle Weathervane...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
