Todays shop time.
/ Todays shop time.
I helped my brother turn a bowl today. I’m not a huge fan of carbide tools, I can get a much better finish with HSS tools but the carbide scraper sure does rough out a bowl fast. And the last picture is some stuff I made a couple years ago. IMG_8556.JPGIMG_8557.JPGIMG_8574.JPGIMG_8562.JPG
/ Todays shop time. #962
A relative novice speaking here, but I'm becoming more a fan of carbide edges. Yeah I use and sharpen HSS gouges frequently, and remove a lot of material with them, but the little carbide inserts have yet to fail me for intricate work or for hybrid material turning.
/ Todays shop time. #963
Should've done this mod a while ago. Added a Wixey Digital Readout to my planer. Wow! Now I can dial it in to .005in accuracy in a jiffy. Always hard to go back and make additional boards at the same thickness without a lot of fussing using a tape measure or rule on the machine.
View attachment 651823 View attachment 651822
Thinking I might 'need' one for my table saw as well. :cool2:
That is pretty cool! Was it just a lot you added on? I would love that on my planers!
/ Todays shop time. #964
Simple project compared to some of the other projects I see done on here. I needed some rollers for a transfer chair. I took the chair apart a couple years ago and couldn't find the original ones so I made some new ones. But, I did find the skiving tool I used 25 to 30 years ago to make the original ones so that saved me some time.
It took 2-1/2 hrs to do the layout, figure out the process and finish the first one, then 45 minutes to make the other 3. No tight tolerances (+/-.005) were needed on these so it was pretty quick to do. Naturally, I made these last Saturday afternoon and found the others Sunday morning. Oh well, it was good practice. Skiving tools are a great way to cut in special shapes when needed.
/ Todays shop time. #965
Very nice and clever way of cutting a radius! :thumbsup:
/ Todays shop time. #966
Maintenance time this evening. Getting tired of my parallel clamps hanging up because of the glue residue on the slide rails. Finally decided to deal with the worst offenders.
A chisel (that isn't my best), some Acetone, a wire brush, beeswax, paste wax, spray lubricant, and some elbow grease. I disassembled and clamped the clamp bar and got on it. Cleaned up and waxed the rails and the acme threads in the heads and re-assembled.
Wow... now these slide better than new... no kidding. Takes about 10min per clamp and SO worth it!
/ Todays shop time. #967
View attachment 652283 View attachment 652280 View attachment 652281 View attachment 652282
That’s MY kind of day.
/ Todays shop time. #968
I need to get some wax on mine. It's one of those things that get put off until I need a clamp and then I fool around trying to keep wax paper it place. Talk about frustrating.
/ Todays shop time. #969
Yep I gave up using wax paper. I just try to wipe drips when I see them during clamping. Tearing them down and cleaning isn’t too bad once you get motivated. Sure is a sweet feeling once you are done.
/ Todays shop time.
I started putting a piece of painters tape across the bar. It’s quick and low hassle.
/ Todays shop time. #971
I've tried that in the past and kind of struggled with that method. Do you get the clamp adjusted very close to the grip length and then put the tape on?
/ Todays shop time.
I just measure the distance to the last glue joint and run the tape an inch farther. If you run it too far it binds up the clamp slider.
/ Todays shop time. #977
I am working on getting a transmission line from my house to my shop, and so I put up an entrance mast. That went well, but after getting an old load box, and starting to wire it, I realized it was not going to work, so I will have to go to Lowes and buy a new one. The one I got is so old it is hard to get breakers for it any more.
I thought I could make due with a 100 amp, 40 amp and 15 amp breaker (it was in the box), but that will not work. I have to have places for the incoming wires at 100 amps, then a 100 amps breaker for the generator. Another 100 amp breaker for the generator control box. And then a 50 amp breaker for my welder...
It's only money I guess, but it would have been nice to make what I had, work! (LOL)
/ Todays shop time. #978
My shop time recently has been working on my UTV.
I found out what happens when you mix two apparently incompatible anti freezes;
The first picture is the old water pump impeller, the second is the new and old impeller, and the third is the housing full of a hard waxy substance
/ Todays shop time. #979
My shop time most recently was getting an early start on Xmas gifts. This one for my BIL. He loves playing guitar and loves cooking. Here is a 16in guitar pick cutting board I just made.
/ Todays shop time. #980
What is the light wood? The grain is great.
2017 DITCH WITCH JT20 HORIZONTAL DRILL (A63276)
2017 DITCH WITCH...
Schaben Pull-Type Sprayer (A66285)
Schaben Pull-Type...
2020 ISUZU NPR 16FT BOX TRUCK (A59914)
2020 ISUZU NPR...
2018 Caterpillar 287D Two Speed Compact Track Loader Skid Steer (A64553)
2018 Caterpillar...
1989 Cheetah Chassis Corp 40ft. 36 Ton T/A Container Trailer (A64556)
1989 Cheetah...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
