to foam or not to foam?
   / to foam or not to foam? #11
So,,,, I just re-read all this.... At my new job we build puppets.. They are made out of all types of crazy foams. I am going to go talk to the tech and see if they have a foam idea for my tires.
I have to say, though. This year I have not had one flat. I think it is related to the fact that the poor machine has been doing so much hard work over the past 4 years clearing our property.
You will find that as time goes on, the land is easier to work. I know ours is.
   / to foam or not to foam? #12
Great Stuff foam, and from what I've seen, all foam used on homes, become soft and brittle in a short amount of time. It will not work in a tire.
I started out using Slime in my tires and felt it worked pretty good. My flats were fewer, but not eliminated. Having the front tires Foamed solved all my problems and it's something that I would do again and again on every tractor that I own. It's not even something I would think about, I would just do it.
There comes a time when you've had enough of down time because of a flat tire. When I hit that point, there was no turning back. If you are asking the question, then you are getting close. One or two more flats and you'll realize that it would have been cheaper to have had the tires foamed already.
Good luck,
Eddie
   / to foam or not to foam? #13
Good luck,
Eddie
I just finished a big mowing job and when it was all said and done i had about 8 flats. Ben realy thinking about foam as i mow for extra money in the afternoons and dont have alot of daylight to work with. Question: (1) what is the cost of foaming tires? (2) how is the ride after doing so (3) do you have to do tube or tubleless tires or does it matter?
Jeremy
   / to foam or not to foam? #14
Jeremy. What kind of Tractor are you using.
I have been told that foaming an 1850 is not a great idea if you are working on severe slopes (over 30) due to the fact the tires work best on ultra low pressure.
Carl
   / to foam or not to foam? #15
I might have mentioned it somewhere on here, in another thread, but I forget what it cost to foam them. I did the front times on my CUT and also the front tires on my backhoe.
They were both tubless tires, that I had foamed and after still getting flats, put tubes into them. The tubes were removed to foam.
They are heavey. Extremly heavy to pick up and move around. On the tractors, I don't notice any difference. I think I did at first, but now it's normal to me.
Eddie
   / to foam or not to foam? #16
Carl
Thanks Carl. I'm have a MF285 open platform 2x4 I use to mow. I pull a 15ft batwing and its real sandy around here. Just wondering if the added weight would give me any trouble in the sand.
Thanks, Jeremy
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
Toro z turn (A56859)
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
