MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,706
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
I think SCUTS and CUTS with R4 tires should probably be loaded. I had a DK Kioti that benefitted a lot from loading the tires in dry conditions. I have a 88 hp 10,000lb Utility tractor with R1 tires that I won't load the tires, it's heavy enough already with FEL and anything on my the rear. There is much more adjustability with R1 tires and mine are set to 90" wide so tipping isn't an issue.
I have lots of wet conditions and loading the tires only makes you dig faster and get stuck quicker, especially with R4 tires.
A lot depends on your conditions, tractor size and tires. Loading the tires isn't for everyone.
Absolutely true. Everyone's circumstances are not the same. You mentioned that your tractor was heavy enough at 10,000lbs, and again, that was for your uses. My 12,000lb tractor could not get all of it's power to the ground at 10,000lbs, I had to go up over the 12,000lb mark to get the most use out of my machine, but again, that is me with my conditions. I do not even consider wet ground as a condition,
