Tn70 shuttle shift problem
   / Tn70 shuttle shift problem #1
Chuck bay
Salem,nj
New holland tn70/tc40. Rtv1100
I'm new to the forum but have fixed many a problem by reviewing the threads on this forum. Unfortunately I'm stuck on what would seem to be a relatively easy problem and I don't want to make anything worse. I have a 2006(roughly) tn70a with a synchro command manual shuttle shift. The shuttle shift started feeling a little loose when I was doing some loader work then the shifter went totally loose. It's stuck in neutral. It was shifting fine prior to the problem. So I take the tire/fender/gas tank out so I can access the shift linkage, there's a roll pin in place, and the shifter moves forward and backward freely but the lever does not move. Im think the roll pin is broken but I can not pull the lever off the shaft to see. Any thoughts would be greatly appreciated.
   / Tn70 shuttle shift problem #2
Have you found your problem? Those levers can be tough to get off. A careful dose of heat can help ease them off.
   / Tn70 shuttle shift problem #3
If you aren't aware of them, there are roll pin punches. They have a nipple in the middle of the tip. Makes it easier to use (they stay centered while driving them).
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
2025 GPS Trailer (A56858)
2025 GPS Trailer...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A56436)
Adams Load Out...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
