Tn70 shuttle shift problem
   / Tn70 shuttle shift problem #1
Chuck bay
Salem,nj
New holland tn70/tc40. Rtv1100
I'm new to the forum but have fixed many a problem by reviewing the threads on this forum. Unfortunately I'm stuck on what would seem to be a relatively easy problem and I don't want to make anything worse. I have a 2006(roughly) tn70a with a synchro command manual shuttle shift. The shuttle shift started feeling a little loose when I was doing some loader work then the shifter went totally loose. It's stuck in neutral. It was shifting fine prior to the problem. So I take the tire/fender/gas tank out so I can access the shift linkage, there's a roll pin in place, and the shifter moves forward and backward freely but the lever does not move. Im think the roll pin is broken but I can not pull the lever off the shaft to see. Any thoughts would be greatly appreciated.
   / Tn70 shuttle shift problem #2
Have you found your problem? Those levers can be tough to get off. A careful dose of heat can help ease them off.
   / Tn70 shuttle shift problem #3
If you aren't aware of them, there are roll pin punches. They have a nipple in the middle of the tip. Makes it easier to use (they stay centered while driving them).
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
MACK T/A DUMP TRUCK (A60430)
MACK T/A DUMP...
2017 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60460)
2017 Peterbilt 567...
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
