TN70- name the part
/ TN70- name the part #21
I guess I don't know the difference between circlips and snap rings other than Americans call them snap rings and Europeans call them circlips.
These are made of spring steel, formed out of wire, and have no loops or hooks of any kind on the ends. For what they cost (vs. the cost of labor @ shop rate), I always figured the easiest, fastest way to get them out was to crimp them exactly in the middle so the halves could easily be picked out of the groove. They can be gotten out whole and re-used.
The housings come out/off as you suggest.
/ TN70- name the part #22
Thanks.
Any other tips for getting the supports (seal/bearing housing) of the tractor?
/ TN70- name the part #24
The easiest way I know of is to pull the shaft out on one side until it falls out of the bearing on the other side. Then use it as punch and tap the other side out. I have not damaged anything so far that wasn't going to be replaced anyway.
/ TN70- name the part #25
That's a good idea that hadn't occurred to me.
/ TN70- name the part #26
thanks. I got the supports out no issues. Got the circlips out fairly easy as well. My trouble was with the seals. I ended up scaring the seal face (seat) of the support while trying to cut seal out with a dremel tool. The cut doesnt go all the way across so I believe with some RTV the seal will still work...I hope. So the other one I was able to bend down the seal from the inside of the support enough to then punch the seal out from the outboard side of the support flange.
/ TN70- name the part #27
Place position and draft levers fully forward/down before removing the bar.
RickB is this required for the draft sensing control lever that rides on the bar? Is the correct position of this roller on the front axle side of the bar? draft sensing follower.JPG
/ TN70- name the part #29
Thanks Harry in KY and RickB
/ TN70- name the part #30
Not really. There isn't much to it. Rotate and tap/pry out.
Rick,
Thanks for all the good advice. We tried replacing the seals and bearings (including O-rings) on our TN75 DA, but still have a bad leak (now both sides). We ordered new parts (including the shaft) and are ready to tackle the job again. You didn't say anything about the best way to install the new seals (and, in our case, the shaft). Do you have any advice for a "shade tree mechanic" on this project?
Thanks again,
Jim in Fla.
/ TN70- name the part #31
Hi I want to put a block heater on a TL80A new holland tractor, and don't know where to start, it is a 2005 model,
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2003 NISSAN 350Z COUPE (A59912)
2003 NISSAN 350Z...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
1998 Freightliner MT45 Step Van Food Truck (A61573)
1998 Freightliner...
UNUSED ATSPOWER GASLESS WELDING MACHINE (A64281)
UNUSED ATSPOWER...
