pycoed
- Joined
- Mar 28, 2007
- Messages
- 179
- Location
- West Wales UK
- Tractor
- Zetor 7045; Yanmar YM1820;Wheelhorses C121, C101, A8;Cushman Turf truckster
Yanmar YM 1820 - does not start via ignition key. Previous owner had disabled connection to the starter solenoid & added jumper wires from solenoid battery & start terminals, now I think I know why.
He had also, wisely in my opinion, added a 25 amp blade fuse link in the white/red ignition switch feed from the starter solenoid. I have now proven all circuits on the tractor. Everything works except the starter connection from the ignition switch. I have proved the cable from the ignition switch via the clutch switch, which works fine, to the vacant wire next to the starter solenoid i.e the original one.
Battery connections are clean & have dielectric grease, ditto earth to chassis removed cleaned greased, replaced - neither looked corroded at all. I've done the same on the solenoid too.
Every single time, with the original tractor wiring connected, when you turn the ignition key to start, this fuse will blow. If I connect a jumper cable from the battery connection on the solenoid to the start connection the engine starts instantly and the 25 amp fuse stays intact. For some reason, which at the moment escapes me, it seems as if with the original wiring the starter tries to draw its start current via the ignition switch rather than the battery cable. At present I am stumped as to why.
I've come back to the house for a coffee & I'm taking the dogs out for a run & clear the brambles away from the transit box that is pencilled to sit behind the Yanmar, then I'm going to try an additional earth strap from a starter mounting bolt to the chassis. I'm half minded to try inserting a starter relay in circuit, but I wanted a simple little tractor & I've already got a thermostart timer I didn't want!!
Opinions gratefully received!
