TITAN ATTACHMENTS TRENCHING BUCKET?
   / TITAN ATTACHMENTS TRENCHING BUCKET?
   / TITAN ATTACHMENTS TRENCHING BUCKET? #15
working in reverse is probably more useful than the front facing ones!
It's made to be reversible. It's better working backwards, as the angle on the fel arms will lift when it digs in too hard.
My tractor has a reverser, so all 12 gear ratios are available forward + backward. Without that, it might get aggravating.
And I should say, my land is very sandy and easy to dig into.
I have cut through thin layers of sand + gravel without any trouble but I can't say how it would perform in rocky ground.
   / TITAN ATTACHMENTS TRENCHING BUCKET? #16
using in reverse can bend the cylinder rods on the loader
   / TITAN ATTACHMENTS TRENCHING BUCKET? #18
I had that happen once, not with the trench bucket though.
It is something to keep in mind during use.
But I can tell you, digging forward with my machine is much more worrisome, the bucket tends to dig in hard and everything gets a bit flexy.
Reverse works better.
   / TITAN ATTACHMENTS TRENCHING BUCKET? #19
using in forward can bend your loader arms more easily
:unsure:
Not true. If by arms I assume you mean cylinders. Going forward puts the cylinders under tension.
   / TITAN ATTACHMENTS TRENCHING BUCKET? #20
Actually, the FEL arms should be strong enough that the tractor can't bend them. On dirt at least.
If they'll bend before the tires start spinning, they won't last long anyway.
My trench bucket has a nasty leverage ratio acting against the tilt cylinder, and it is vulnerable. That's a design compromise to achieve the depth I need to bury electrical cables to local code.
VINTAGE EVINRUDE OUTBOARD MOTOR (A58374)
VINTAGE EVINRUDE...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2010 Chevrolet Traverse SUV (A56859)
2010 Chevrolet...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
16ft T/A Flatbed Trailer (A55758)
16ft T/A Flatbed...
NEW Long Forks (A59000)
NEW Long Forks...
