Titan Attachments Experience
   / Titan Attachments Experience #23
I bought from both EA and Titan, both worked out well and the equipment was great. I recently switch my tractor from pin on to that SSQA using titan's adaptor (the red one pictured above). All in all its very overbuilt for the tractor I used it on (32hp) and would be great, probably even for and older skid steer as far as strength. I cut a lot of metal off of it to lighten it up to not take away from my lifting capactity and It worked out wonderfully. Welding the plates on the buckets is nothing, just cutting the ears off cleanly take a bit of work. I say I maybe have 8 hrs into cutting ears off of two buckets, converting a pallet fork setup over and welding/ painting everything. Definatly worth it. I also didn't want to pay 900$ for just the QA setup. I think I have like 600$ into the adaptor, and 3 mount plates from Titan. That price, I could swallow a bit easier.
If i ever convert another bucket i will cut around the brackets thru the back of the bucket and use the 2 "windows" for additional welding.
   / Titan Attachments Experience #24
That's a good idea. My bucket has a lot of patches anyway. Thanks. My only worry is that my bucket is curved where the pin attachment is and the Titan attachment is flat.
   / Titan Attachments Experience #25
I got mine from palletforks.com (site sponsor, pretty sure they are Titan). The ears that the pins push into on the bottom of the SSQA interface were way out of spec & would barely engage, much less tighten up correctly. Emailed them along with a photo & got a reply surprisingly quick. They would ship me a new frame or a $70 credit (for a local welder to fix things). I welded a couple pieces of bar stock up myself to tighten things up. Decent product at a cheap price with good support.
I purchased a grapple from Titan and had the same issue that the lower ears were way to long and out of spec. I had to cut about 3/4" off and weld it back up so the pins would engage. They responded quickly when I notified them of it but kinda set me off since there is a detailed specification about this dimension and they chose not to follow it.
   / Titan Attachments Experience #26
I bought a SSQA hitch from Titan, back when they were called "atvxpress" on eBay. Despite being clearly laser-cut and very well made, it did not quite fit the SSQA. They took care of it immediately and had it fixed.
Wouldn't hesitate to buy from them again. I think it may have been a shipping issue or something as like I said, it was clearly well made.
   / Titan Attachments Experience #27
Just got my Titan 48" Pallet forks today. They fit like a glove, nice and tight no slop. Maybe they have changed things?
   / Titan Attachments Experience #28
They must have, my 48s fit a little loose, but not bad.
   / Titan Attachments Experience #29
Ordered set of Titan 48" pallet forks last Friday. Received a call from R&L freight mid day today. They will be delivering right after lunch Thursday. Asked them to make sure that rear of forks was facing rear of trailer so I could just drive up to back of truck with tractor and hook onto the SSQA with tractor. They said no problem.
Did this when our grapple was delivered to Ranch and was EZ-PZ. Hooked up to grapple's SSQA and yanked grapple and pallet. Paper work took longer than unloading.
   / Titan Attachments Experience #30
My Titan forks were shipped with the forks off of the frame and all three strapped flat to a pallet
2018 Ford Escape SUV (A50324)
2018 Ford Escape...
TOYOTA 7FGCU25 LP SIT DOWN FORKLIFT (A50854)
TOYOTA 7FGCU25 LP...
2015 MACK GU713 (A50854)
2015 MACK GU713...
2012 John Deere 7280R MFWD Tractor (A51039)
2012 John Deere...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2015 Ford F-450...
2005 Pierce Enforcer Fire Truck (A50323)
2005 Pierce...
