Titan Attachments Experience
   / Titan Attachments Experience #11
If I buy the titan ssqa plate, will it work on a JD 67 loader on a JD 750 tractor so that I can buy an EA 50 in grappler.
If your loader has a pin-on bucket, you will need something like the attached to convert to using SSQA implements
http://www.everythingattachments.com/Quick-Attach-Adapter-Plate-p/wrl-apum.htm
You will need something like this welded onto your existing bucket to be able to use it as SSQA
http://www.palletforks.com/skid-steer-attachments/mount-plates.html
   / Titan Attachments Experience #12
   / Titan Attachments Experience #18
sorry im not familiar with the JD system but they built the wicked grapple (i have one) to incorporate the JD imatch (whatever the jd pin on front one is called) at no addl charge.
It comes std with the universal SSQA mount on the implement side but they will add other mounts if requested.
Give EA a call there great folks to deal with.
   / Titan Attachments Experience #19
I bought from both EA and Titan, both worked out well and the equipment was great. I recently switch my tractor from pin on to that SSQA using titan's adaptor (the red one pictured above). All in all its very overbuilt for the tractor I used it on (32hp) and would be great, probably even for and older skid steer as far as strength. I cut a lot of metal off of it to lighten it up to not take away from my lifting capactity and It worked out wonderfully. Welding the plates on the buckets is nothing, just cutting the ears off cleanly take a bit of work. I say I maybe have 8 hrs into cutting ears off of two buckets, converting a pallet fork setup over and welding/ painting everything. Definatly worth it. I also didn't want to pay 900$ for just the QA setup. I think I have like 600$ into the adaptor, and 3 mount plates from Titan. That price, I could swallow a bit easier.
   / Titan Attachments Experience #20
I got mine from palletforks.com (site sponsor, pretty sure they are Titan). The ears that the pins push into on the bottom of the SSQA interface were way out of spec & would barely engage, much less tighten up correctly. Emailed them along with a photo & got a reply surprisingly quick. They would ship me a new frame or a $70 credit (for a local welder to fix things). I welded a couple pieces of bar stock up myself to tighten things up. Decent product at a cheap price with good support.
AMCO F42B-3626CS 13ft Pull-Behind Wheel Offset Harrow Tiller (A49461)
AMCO F42B-3626CS...
Delta Consolidated Fuel Tank 48000 (A51039)
Delta Consolidated...
2022 JCB HM180T Hydraulic Breaker Excavator Attachment (A49461)
2022 JCB HM180T...
(2) 15X8 RIG MATS (A50854)
(2) 15X8 RIG MATS...
2005 John Deere 824J Articulated Wheel Loader (A49461)
2005 John Deere...
DITCH WITCH R300 STAND ON TRENCHER (A51242)
DITCH WITCH R300...
