Tires Tires
/ Tires #1
Auz
N.W. Oregon
Kubota B21
I have a spare set of front wheels for a B21. The tractor has Industrial tires all the way around now. Could I put Agricultural tires on the spare front wheels to use in the mud? The industrial front tires on it now are about 50% tread and the rears 99%, so the gearing ratios are not exactly even now. I have gravel and dirt ( soon to be mud ) only, no pavement.
/ Tires #2
Compare the circumferences of the tires that belong on the tractor with those that are on the tractor. Do the same with those that you intend to purchase. I believe that the rule of thumb is a 10% differential is allowable as long as there is slippage available.... i.e... using on turf, dirt, or snow. The circumference only comes into play when you are in 4 wheel drive, so I don't see how you can get into trouble if you keep the proper circumference the same...
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
New/Unused Landhonor 21ft x 13ft Metal Carport (A65583)
New/Unused...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
2018 GEHL RS5-19 GEN3 TELESCOPIC FORKLIFT (A65053)
2018 GEHL RS5-19...
2014 Kobelco SK210LC Hydraulic Excavator (A64553)
2014 Kobelco...
Stout Buckets HD72-3 Rock Bucket Skid Steer Grapple (A65640)
Stout Buckets...
