tires
/ tires #1
Waterrat
I am in a pickle. I own a little grey market kubota tractor, with a tire size of 4.00*10 and can't seem to find a replacement. Any suggestions where I can look in North America? Any help would be greatly appreciated.
/ tires #2
Welcome to TBN Wr.
Measure your rim width, I know it's a ten inch rim but if you know the width, then you can find a set of tires that'll fit. They won't be the same tires, but they'll work and be new.
Here's a ten inch tire, if the width of your rims are close maybe these will work? Look around in here " Titanョ Tire catalog "
and check this one out " Titanョ Tire catalog " The rim width info is there, (it's 5.5" for this tire)
/ tires
One of the concerns I have is that it is a 4*4 and I am a bit worried about the limited slip differential. Thank you for the posting, I am searching though the web pages! :) it is greatly appreciated.
/ tires #4
Great' find out the rolling circumference of front and rear tires and use that info to make your choices.. There are places you can get rims from if needed..I think you can find something and stay within your front assist ratio. You'll have to do some research though..;)
The ratio looks something like this "1.456", it means the ratio is: rear tires are that much large (rolling circumference) than the fronts. I went through this a few years ago my ratio on a J. Deere was 1.571.
Took this off the web
Can I use a different size tire on my 4wd tractor?
Proper tire sizing/matching on front wheel assist tractors is a function of insuring that the front axle 'lead" specification is kept within acceptable design and operational limits. Front axle lead (or slippage) is necessary on front wheel assist tractors in order to realize the benefits of front axle tractive assistance. Desired front axle lead is expressed as a positve increase in front axle speed over that of the rear axle, usually in terms of percentage (ideally +1%-+5% for most front wheel assist tractors). Lead percentages outside of this range will lead to problems such as accelerated tire wear, difficult steering, loss of tractive assistance from the front axle as well as increased drive train wear with premature failures. Negative lead (or slippage) will, from the outset, totally negate any potential advantages offered by front wheel assist. Determination of the front axle lead (slippage) for a given tractor is easily determined if one has access to the following information;
Front tire rolling circumference
Rear tire rolling circumference
Front/Rear drive train ratio of the subject tractor
Rolling circumference specifications are available from the tire manufacturer. This is the only tire "specification" that matters for this calculation. Rim size is of no importance at this point.
Drive train ratio is available from the tractor manufacturer.
Calculation for determining front axle lead is as follows; Front Tire rolling circumference x Front/Rear drive train ration %Slippage= Rear Tire rolling circumference Example; Front tire size- 11.2x24 with rolling circumference of 129.6" Rear tire size- 18.4-28 with rolling circumference of 175.9" Tractor Front/Rear ratio= 1.4 129.6 x 1.4 181.44 175.9 = 175.9 = 1.031 (1.031-1) x100 = percentage 1.031-1 = .031 .031 x 100 = +3.1% front lead (Good!) Now, what will occur if we substitute a rear tire size of 18.4x30 having a rolling circumference of 183.5"? 129.6 x 1.4 181.44 183.5 = 183.5 = 0.989 (0.989-1) x100 = percentage .0989-1 = -.011 -.011 x 100 = -1.1% front lead (Notice that this is negative lead meaning the rear axle is over- running the front axle. This is obviously a bad choice of rear tire size for the given front size. In order to use the 18.4x30 tires on this tractor, it would be required as well to install 12.4x24 front tires having a rolling circumference of 137.0". This will result in a lead of +4.52% which is within the desired range of +1.0%-+5.0%. If you have owned a 4wd tractor for any length of time, you have probably noticed that the front tires have a tendency to wear at a higher rate than the rear tires. This is normal. Keep in mind that, because of the design slippage of the front axle, when 4wd is engaged the front axle is, in effect, trying to "outrun" the rear axle. Since the rear axle is supporting 60% of the total tractor weight, the front axle cannot drag the rear axle along with it at its slightly increased speed; therefore the front wheels must be content to slip (or spin). Did you ever watch a teenager "peel out" at a red light? This is exactly what is occurring in the front axle, only at much lower speeds with the associated tire wear being nearly imperceptible. Interesting to note is the fact that the rate of front tire wear decreases as the tread wears. As the tread wears down, rolling circumference is reduced, bringing the front axle lead (slippage) percentage closer to 0%. This serves to illustrate why it is important to be judicial in the use of 4wd, avoiding usage on hard surfaces as much as possible. A related subject is the use of front loaders on front wheel assist tractors. Ideally you want to maintain a load bearing ratio between the front and rear axles of 40%front/60%rear. Asking the front axle to carry more than this share is setting yourself up for expensive repairs down the road. It is important to use appropriate counter-balance on the rear of the tractor to offset the loads that are carried in the loader bucket. Take note that front axle components are generally smaller and of lighter construction than the rear axle. These front axle components were not designed to support 60%, 70% or in some extreme cases up to 90% of the total "load".
If your rear axle is scooting along, just barely contacting the ground now and then, this means the front axle is supporting near 100% of the total weight of the tractor, loader and bucket payload! This is an almost iron-clad guarantee of front axle failure! Be cautious when changing tire sizes. Even the same size from different manufacturers can have a significant impact on front axle leads.
/ tires #5
Are your fronts and rears ag or turf.. or something more agressive like a rice tire?
soundguy
/ tires
Thanks for all your responses. I did find a tire with the right rolling diameter, and all the goodies, just not one that will fit the rims that I have. Which really sucks. So now, I am hunting to find new rims. I am basically going to cut, and weld the two rims together. However, I am having a **** of a time find 4 by 12 " rims! Any suggestions? I guess I can look at it this way..either I need to find a 4.00*10 R1 tire or a 4*12 inch rim...that I can hack to pieces.
Thoughts for rims? either? Thanks
Cheers
/ tires #7
Good, you're heading in a productive direction. Make sure of the rim's width also. I remember a few threads on here about doing exactly what you're thinking about. I also remember that someone found a place that will make rims for your needs..I can't remember the name of the company though..It is somewhere here maybe a couple years ago, the guy was fairly happy with the price also.
Maybe someone that checks this thread will know and help you out.
2022 Chevrolet Tahoe SUV (A61569)
2022 Chevrolet...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61568)
2016 Volvo VNL T/A...
UNUSED INDUSTRIAS AMERICA F07-7' LAND LEVELER (A62130)
UNUSED INDUSTRIAS...
2006 Vermeer BC1000XL Chipper (A61166)
2006 Vermeer...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2006 Hummer H3 4WD SUV (A61569)
2006 Hummer H3 4WD...
