Tires Tires, Rims and Tubes.
   / Tires, Rims and Tubes. #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
My property is a jungle. It is rough nasty terrain. Lots of sticks limbs and stuff that either pops off valve stems, jams into rim seals and causes leaks or the worst, punctures sidewalls (I have never punctured a tire in a "normal through the tread fashion).
Also most of my rims are in tough shape.
I have converted all my rims to metal stems. But now due to a couple of side wall punctures I am going to have to tube some tires. The previous results have been bad. Valve stems completely ripped off and have to replace the tube.
Now I have a crazy idea. What if I were to weld "guards" around the tube valve stems. Like a 1" piece of pipe. Just long enough to go past the stem. Close enough to service. It would have to be notched and stuff. Not an easy peasy process but... Then maybe throw in some of my gemplers stuff that I have been sitting on for more than a year.
I have spent so much converting to metal valve stems this solution sucks but.
Anyway, wanting to get your guys thoughts on this... No sense throwing good money after bad...
   / Tires, Rims and Tubes. #2
MVC-026F.JPGWe've found guards to be the anwer to broken valve stems. We use our tractors close to vine rows and used to have the stems broken too regularly.
We use steel tube of about 2" OD welded on in three little spots where the square cut end touches the rim. (see photos)
From memory we even managed to do the small welds without removing the water filled tube (and tyre) from the rim.
For damaged tubes it's possible (in Australia anyway) to buy glue on valve stems and they work. I think the stems and adhesive were made by Rema?
Regards Allen
Exactly what I am looking to do. Thank you for the pix. My only real issue is that the PT rims are the same size of a small cars tire... 12" thick (30cm) but not all that tall.
Where in Australia are you? I have friends in Perth and Sydney. Never get to see them except when the come state side. Haven't been to Sydney in years..
Carl
   / Tires, Rims and Tubes. #4
I'm about 70Km (45-50 miles) North East of Adelaide which is nearly halfway from Sydney to Perth.
The Barossa Valley is one of Australia's best known wine districts.
If you're ever in the vicinity email me and I'd be happy to give you a guided tour of the district.
Regards Allen
   / Tires, Rims and Tubes. #5
So that would be...Tanunda? Bethany? Krondorf?
What grapes do you grow on your vineyard? (Do you have a wine label we should look for over here?) We're just a little high and dry here to grow grapes.
It's great to see the big green tractors again- I used a Deutz when I was younger. It was a great machine.
All the best,
Peter
Regards Allen
   / Tires, Rims and Tubes. #6
Does anyone know of other sources for these rims to fit the 26x12.00x12 tires, i.e. 10.5" wide rims with dual offsets?
JJ posted a link awhile back, but they no longer sell those rims.
All the best,
Peter
woodlandfarms said:
....Also most of my rims are in tough shape...
   / Tires, Rims and Tubes. #7
All the best,
Peter
I had the local wheel and rim place make two rims for my PT-1445. I had the center section made with 3/8 in steel and off set. Cost was around $ 75.00 each.
I think the Ditch Witch trenchers use a wide rim similar to mine.
   / Tires, Rims and Tubes. #8
JJ,
Do you have the 16.5x10 loader tires, or do you have the R1 tires like the 18XX (26x12.00x12 NHS)?
Were the rims to replace existing rims that you had, or did you do duals on two rims?
Thanks,
Peter
   / Tires, Rims and Tubes. #9
ponytug said:
JJ,
Thanks,
Peter
I have the 26X12X12 tires. Just extra rims for extra tires.
   / Tires, Rims and Tubes. #10
Ponytug,
Tanunda, no I don't have a label, fruit is sold to Barossa Valley Estate (E & E, Ebenezer and E - Minor are in the range sold into the US.
Fruit is also sold to Peter Lehmann Wines and R Wines, both also sold in the US, the latter based in the US and owned I think, by Dan Phillips.
I grow Shiraz, Cabernet Sauvignon, Merlot, Grenache, Pinot Noir, Chardonnay, Semillon and Gerwurtztraminer.
Have just started the 08 harvest, did Pinot last Wed. and Traminer will be harvested Sun. night for Mon. delivery.
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
VERMEER 605F ROUND HAY BALER (A51247)
VERMEER 605F ROUND...
CAT Skid Steer (A50322)
CAT Skid Steer...
(INOP)NISSAN 40 WAREHOUSE FORKLIFT (A51247)
(INOP)NISSAN 40...
(4) 5 LUG WHEELS & TIRES (A51248)
(4) 5 LUG WHEELS &...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A53426)
2018 INTERNATIONAL...
