tires cut, but how?
   / tires cut, but how? #11
If I am looking at the pictures right it looks more like a straight cut rather than a circular cut that would be made if the rotating tire sideswiped something. Is it possible it was hit by something else passing by? If the tire was rotated so the slice was horizontal and positioned at the top side of tire rotation, would it be at truck bed level?
   / tires cut, but how? #13
The local tire store's newest salesman?:)
Is the tire useable?
   / tires cut, but how? #14
It sure does look like vandalism, thats a pretty nice cut.
one of the cuts has widened, not sure if it's due to the temperatures. it doesn't appear to be leaking, but a failure while I'm using the loader would be bad.
   / tires cut, but how? #16
looks like a factory seam to me. looks too smooth and even to be a cut of some kind.
Keep the chains on it so you won't be hit with flying rubber when it explodes. :)
the cuts are in an arc, but doesn't follow the seam. the arcs are closer the the wheel in the middle, and closer to the tread of the tire at the ends
the cuts are in an arc, but doesn't follow the seam. the arcs are closer to the wheel in the middle, and closer to the tread of the tire at the ends.
   / tires cut, but how? #19
Its a shame, those tires don't look that old.
only 160some hours on them.
I did an experiment. I held a marker stationary, and rolled this can lid past it. The pattern is the same as the cuts.
can ice be sharp enough to cut a tire like that? I can't think of anything else I've run close enough too.
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
1996 Isuzu NPR Box Truck, VIN # 4KLB4B1R8TJ000333 (A57453)
1996 Isuzu NPR Box...
Stanley hydraulic power pack (A56435)
Stanley hydraulic...
1988 FONTAINE TRAILER CO. 50 STEP DECK LOADER TRAILER (A58214)
1988 FONTAINE...
2021 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52705)
2021 CATERPILLAR...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
