Tired of flats myself
   / Tired of flats myself #1
marrt
Platinum Member
Northern VA
Power Trac 1845 and 425
Inspired by Sedgewood's example, and YAFOMPTM (Yet Another Flat On My Power Trac Mower), I decided to address this problem once and for all (I hope). After an exhaustive search, I discovered the tires in the Attachment. I ordered...they arrived three days later. I'll try them this weekend. $30 + $6 shipping per tire/wheel. Not too bad. Carefree Tire
Another Pic.
Yes, they are for the mower. I think most PT finish mowers use a tire size commonly called 4.10/3.50. These are usually 10.x inches diameter. I ordered the 4" centered hub with 5/8" bearing. This will fit the 425 finish mower.
   / Tired of flats myself #7
Is this a solid tire??
If it is, why not exchange your tire with PT for free? I have posted this on TBN many times and there are still people going out and buy ing something that PT will send you for free.
Am I missing something here? /forums/images/graemlins/confused.gif
   / Tired of flats myself #8
Will they do this on a four year old attachment?
Bob Rip
   / Tired of flats myself #9
I think the exchange is only done a) for mowers which are still under warranty, AND b) the owner can somehow verify/document chronic, ongoing problems with the tires rolling off their rims. You send the defective tires/wheels to PT and they replace with airless units.
I don't believe that flatting per se even on a regular basis, qualifies for an exchange, but I could stand corrected on this.
   / Tired of flats myself #10
I stand corrected as you're probably right with that point. Especially with a 4 year old mower deck.
Well at least you have found a solution to the problem. My solid tires while a little more bouncy, never give me any problems, you will love them!
   / Tired of flats myself #11
Wish I had read those posts about the free tire exchange.. probably did and just don't remember.. boy do I feel stupid.. well I guess I can send my old wheels in and get an extra set in case they go flat
   / Tired of flats myself #12
<font color="red">Wish I had read those posts about the free tire exchange.. </font>
Ditto /forums/images/graemlins/tongue.gif
Well...the tires I bought did not work. The mower started pushing them off the rims within the first hour of mowing. Back to the drawing board. Guess I'll call PT. BTW, my mower is the 1845 finish mower and it's 5 years old. Not sure if they still use the "4.10" size tire now or a larger one. I know they use the larger one on the rough cut mower. I doubt they'll replace them free...but I'll check. If I have to go with the larger one, I'll have to buy the spindles as well.
   / Tired of flats myself #14
Marrt:
On the rough-cut, I rolled both the factory tires off after a season. They were tube tires, filled with foam when I got it from PT. I took them to a local outdoor power store who sent them out and got tubeless tires mounted and filled with rubber foam. The difference is the filler is firmly stuck to the wheel, where before I rolled tire and tube both off.
I've got two mowing seasons on the filled tires with no problem.
   / Tired of flats myself #15
I just put inner tubes in the tires of the rought cut mower about 3 to 4 years ago and have not had a problem since. No leaks, no flats, no problems.
Bob Rip
   / Tired of flats myself #16
<font color="red"> Well...the tires I bought did not work. The mower started pushing them off the rims within the first hour of mowing. Back to the drawing board. Guess I'll call PT </font>
When I called PT they sent me what you bought - they didn't work any better for me than they did for you and Charlie /forums/images/graemlins/frown.gif Mowers as heavy as ours need pretty tough wheels & tires. Charlie has presented his effective solution to the problem. I went even heavier and also have had no problems since. Here's my solution.
PT sure has a knack for over-engineering their steel work and under-engineering many of the smaller bits, especially wheels & tires. At least they're giving us a solid base worthy of our creative upgrades.
We like Participative Tractoring /forums/images/graemlins/tongue.gif
Sedgewood
   / Tired of flats myself #17
I solved similar problems with flats by putting tubes inside the "tubeless" tires. For me it has been a relatively inexpensive solution that has worked on the mower as well as on my 1845 tractor.
   / Tired of flats myself #18
Welcome Johnny. Good to see another 1845 user on board.
   / Tired of flats myself #19
Welcome
How long have you owned your 1845? What projects are you working on or have completed that you can share?
PJ
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
2016 CATERPILLAR 311FLRR EXCAVATOR (A60429)
2016 CATERPILLAR...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2013 Ford Taurus Sedan (A59231)
2013 Ford Taurus...
2021 CATERPILLAR D5 LGP HIGH TRACK DOZER (A60429)
2021 CATERPILLAR...
